Thor DP3 error
After the DP3 connection has been established for a period of time, the driver reports an error, and unplugging and replugging the DP connector does not resolve the issue.
DP Link Rate : [8.1GHz]
[ 24.257276] es7210_set_bias_level standby
[ 347.102762] dce: dce_client_ipc_wait:378 Client [0] unexpected err: [-110]
[ 347.102768] dce: dce_ipc_send_message_sync:554 Error in waiting for ack
[ 347.102777] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967186
[ 347.102778] NVRM: _dceRpcIssueAndWait: NVRM_RPC_DCE: Error while issuing RPC [0xffffff92]
[ 347.103060] dce: dce_ipc_send_message:469 Error getting next free buf to write
[ 347.103061] dce: dce_ipc_send_message_sync:546 Error in sending message to DCE
[ 347.103063] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967268
[ 347.103064] NVRM: _dceRpcIssueAndWait: NVRM_RPC_DCE: Error while issuing RPC [0xffffffe4]
[ 365.534960] dce: dce_ipc_send_message:469 Error getting next free buf to write
[ 365.534967] dce: dce_ipc_send_message_sync:546 Error in sending message to DCE
[ 365.534970] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967268
[ 365.534972] NVRM: _dceRpcIssueAndWait: NVRM_RPC_DCE: Error while issuing RPC [0xffffffe4]
[ 411.674759] usb 1-2: new high-speed USB device number 5 using tegra-xusb
[ 411.827176] hub 1-2:1.0: USB hub found
[ 411.827561] hub 1-2:1.0: 4 ports detected
[ 412.218755] usb 1-2.3: new full-speed USB device number 6 using tegra-xusb
[ 412.435529] input: Compx 2.4G Wireless Receiver as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.3/1-2.3:1.0/0003:25A7:FA70.0001/input/input6
[ 412.590950] hid-generic 0003:25A7:FA70.0001: input,hidraw0: USB HID v1.10 Keyboard [Compx 2.4G Wireless Receiver] on usb-a80aa10000.usb-2.3/input0
[ 412.595761] input: Compx 2.4G Wireless Receiver Mouse as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:25A7:FA70.0002/input/input7
[ 412.595972] input: Compx 2.4G Wireless Receiver as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:25A7:FA70.0002/input/input8
[ 412.596198] input: Compx 2.4G Wireless Receiver Keyboard as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:25A7:FA70.0002/input/input9
[ 412.655030] hid-generic 0003:25A7:FA70.0002: input,hidraw1: USB HID v1.10 Mouse [Compx 2.4G Wireless Receiver] on usb-a80aa10000.usb-2.3/input1
[ 412.834580] usb 1-2.4: new full-speed USB device number 7 using tegra-xusb
[ 413.055562] input: Logitech USB Receiver as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C52F.0003/input/input10
[ 413.055949] hid-generic 0003:046D:C52F.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-a80aa10000.usb-2.4/input0
[ 413.059870] input: Logitech USB Receiver Consumer Control as /devices/platform/bus@0/a80aa10000.usb/usb1/1-2/1-2.4/1-2.4:1.1/0003:046D:C52F.0004/input/input11
[ 413.119191] hid-generic 0003:046D:C52F.0004: input,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-a80aa10000.usb-2.4/input1
[ 414.592575] dce: dce_ipc_send_message:469 Error getting next free buf to write
[ 414.592583] dce: dce_ipc_send_message_sync:546 Error in sending message to DCE
[ 414.592586] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967268
[ 414.592588] NVRM: _dceRpcIssueAndWait: NVRM_RPC_DCE: Error while issuing RPC [0xffffffe4]
[ 414.592596] nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (Lenovo Group Limited LEN T2424pA (DP-2)) is not supported on this GPU.
[ 414.593788] dce: dce_ipc_send_message:469 Error getting next free buf to write
[ 414.593792] dce: dce_ipc_send_message_sync:546 Error in sending message to DCE
[ 414.593795] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967268
[ 414.593797] NVRM: _dceRpcIssueAndWait: NVRM_RPC_DCE: Error while issuing RPC [0xffffffe4]
[ 414.593804] nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (Lenovo Group Limited LEN T2424pA (DP-2)) is not supported on this GPU.
[ 414.595242] dce: dce_ipc_send_message:469 Error getting next free buf to write
[ 414.595245] dce: dce_ipc_send_message_sync:546 Error in sending message to DCE
[ 414.595248] NVRM: dceclientSendRpc_IMPL: Send RPC failed for clientId 2147483648 error 4294967268
DP.error.txt (165.3 KB)
How many display is on this board?
nvidia thor jetpack 7.1
our board use DP2 DP3, (DP0 ,HDMI 1 not use)
  1. Is DP2 also hitting the same issue too?
  2. What does that mean after a while? so it could work in the beginning?
    — no, DP2 work good,
    — it can work begin, I modified the screen resolution and DP Link Rate, and the problem hasn’t been reproduced yet.
If you hotplug the DP3 monitor after you boot up the system already. Will it happen?
hotplug did not reproduce the issue.
This seems to be a probabilistic occurrence; no pattern has been found yet.
Please check if issue would only happen if you boot up with UEFI logo shown on it.
—no , it happen at 414S,
Use DP, the bug is random, and this bug is not guaranteed to happen.
please check this dmesg ,
https://forums.developer.nvidia.com/uploads/short-url/fdqw8Pr510XcKiT6WUFvWxWQO6P.txt
please find a method that could reproduce issue. we will try on NV devkit.
DP0&DP1&DP2是否也有同样的问题?
Jetpack7.2 already fixed this issue. Please try first.
