DRIVE OS Version: Provide DRIVE OS version. Example: 7.2.3
Issue Description: Thor is no more booting up correctly. Display is dark.
booting via connected minicom gives this log:
NvShell>mcureset
Info: Executing cmd: mcureset, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Reseting
INFO: MCU_SYSSTATEMNGR: State update notification received- 3
INFO: MCU_PLTFPWRMGR: MPFDTI Timer is stopped
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring disable.
INFO: NVMCU_SOCPWRCTRL: Wait for Safe Shutdown notification (20s max)
Check for VRS10…
Check for VRS10…
Check for VRS10…
INFO: NVMCU_SOCPWRCTRL: VRS10/11 BIST configuration done!
MCU_FOH: SPI : E2E_P05Check Status : 7 : 0
ERROR: MCU_ERRHANDLER: McuFoh : ReporterID - 0x810E ErrorCode - 0x3
I:RptrID - 0x810B PsCd - 0x8 - VMON Seq Record
I:RptrID - 0x810B PsCd - 0x7 - VMON Seq Match
I:RptrID - 0x810B PsCd - 0x23 - VMON Seq Ackld
INFO: PLTFPWRMGR_ETHCTRL: Ethernet peripherals de-initialized
INFO: MCU_PLTFPWRMGR: Request Eth deinitialization done !
INFO: PLTFPWRMGR_ETHCTRL: Linkup status is not active
INFO: MCU_PLTFPWRMGR: Soc TMON disable.
INFO: MCU_PLTFPWRMGR: Board TMON disable.
INFO: PLTFPWRMGR_IOHWABS: Power down sequence is complete !
INFO: PLTFPWRMGR_IOHWABS: Adding Delay of 5s for poweroff
Status 0
*************** NvShell Initialization Start******************
DRIVE-V7.2.3-P3960-AFW-RH850-U2A16-3.03.02
Inforom detected Board ID - 63960-0010-000
Compilation date: Dec 8 2025, 22:00:19
Enter ‘help’ to see the available commands.
*************** NvShell Initialized *************************
Press ‘Enter’ for NvShell prompt
INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Red Blk, SId-12, JobRes-0
INFO: MCU Version PIM- DRIVE-V7.2.3-P3960-AFW-RH850-U2A16-3.03.02
INFO: PLTFPWRMGR_IOHWABS: Identified Board from Inforom - Board - 3960, BoardId - 000, Sku - 0010
INFO: PLTFPWRMGR_IOHWABS: NumSoc: 1
INFO: PLTFPWRMGR_IOHWABS: MCU reset 0x3 triggered…
INFO: MCU_PLTFPWRMGR: Number of SoCs to be powered: 1
INFO: MCU_BOARDVMON: Loading up common ADC Configuration for boards : TS2/TS3/TS4
INFO: FanMon_IoHwAbs: FAN Tach sensor measurement started
INFO: MCU_LCMCLIENT: MCU_LCMClient initialized successfully
I:RptrID - 0x810D PsCd - 0x16 - PwrCtrl Init Ok
I:RptrID - 0x810D PsCd - 0x16 - PwrCtrl Init Ok ErrAttr - 0x01
I:RptrID - 0x810F PsCd - 0x7 - BootchainCfg Cfg Range Check Success
I:RptrID - 0x810F PsCd - 0x2 - BootchainCfg NvM Read Success
I:RptrID - 0x810F PsCd - 0x4 - BootchainCfg NvM Plaus Check Success
MCU_FOH: Switched to IDLE_STATE
MCU_FOH: Initialization done
INFO: MCU_PLTFPWRMGR: Powering up
INFO: MCU_SYSSTATEMNGR: State update notification received- 1
I:RptrID - 0x810A PsCd - 0xF - ISTManager:IST execution status read success.
I:RptrID - 0x810A PsCd - 0xE - ISTManager:No plausibility error in NVM data.
I:RptrID - 0x810A PsCd - 0x14 - ISTManager:No range plausibility error in NVM data.
INFO: PLTFPWRMGR_IOHWABS: PMIC: Wakeup Status - 0x1, Error Status: 0x0
INFO: MCU_BOARDVMON: Voltage Monitor enabled for ADCJ0 and ADCJ1 signals
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (547mV)
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (29mV)
INFO: MCU_PLTFPWRMGR: SW Latent Test configuration: 0x0
INFO: PLTFPWRMGR_IOHWABS: KL30_PROTECT Voltage (12698mV) exceeded threshold (6689mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: SAFE_3V3_PG Voltage (3261mV) exceeded threshold (3135mV). Continuing…!
I:RptrID - 0x810D PsCd - 0x8 - PwrCtrl Dio Chk Ok
I:RptrID - 0x810D PsCd - 0x7 - PwrCtrl Config Ok
I:RptrID - 0x810D PsCd - 0x17 - PwrCtrl PrePwrUp Ok
INFO: MCU_PLTFPWRMGR: MPFDTI Timer started with period set to - 28800 seconds
INFO: PLTFPWRMGR_IOHWABS: VBAT_SOC_FAULT is set to 1. Continuing…!
INFO: PLTFPWRMGR_IOHWABS: PWRYNK_SHDN is set to 1. Continuing…!
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (5004mV) exceeded threshold (4751mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (12107mV) exceeded threshold (6695mV). Continuing…!
I:RptrID - 0x810B PsCd - 0x20 - VMON Config Valid
I:RptrID - 0x810B PsCd - 0x13 - VMON i2c addr load passed
I:RptrID - 0x810B PsCd - 0xA - VMON Bist Passed
Check for VRS10…
I:RptrID - 0x810D PsCd - 0x3 - PwrCtrl I2C Read Ok
I:RptrID - 0x810D PsCd - 0x6 - PwrCtrl I2C Read Crc Ok
Check for VRS10…
I:RptrID - 0x810D PsCd - 0x14 - PwrCtrl VRS10 BIST Complete
I:RptrID - 0x810D PsCd - 0x19 - PwrCtrl VRS10 BIST Ok
Check for VRS10…
Check for VRS10…
Check for VRS10…
I:RptrID - 0x810D PsCd - 0x9 - PwrCtrl Vrs10 Int Ok
Check for VRS10…
I:RptrID - 0x810D PsCd - 0xD - PwrCtrl ActShdn Ok
Check for VRS10…
I:RptrID - 0x810D PsCd - 0xF - PwrCtrl ActSlp Ok
Check for VRS10…
I:RptrID - 0x810D PsCd - 0xE - PwrCtrl Actslp Ok
INFO: WAR: NVMCU_SOCPWRCTRL: Program correct OTPs for Power sequencing
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
INFO: NvMCU_SocTMON: Soc-0 Temperature sensor initialized
I:RptrID - 0x810C PsCd - 0x17 - TMON Configuration in default mode pass
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS11-1…
Check for VRS11-2…
Check for VRS11-1…
I:RptrID - 0x810D PsCd - 0x1A - PwrCtrl VRS11 BIST Ok
Check for VRS11-2…
Check for VRS11-1…
I:RptrID - 0x810D PsCd - 0xA - PwrCtrl VRS11 Int Ok
Check for VRS11-2…
I:RptrID - 0x810D PsCd - 0x2 - PwrCtrl I2C Write Ok
Check for VRS11-1…
I:RptrID - 0x810D PsCd - 0x4 - PwrCtrl I2C Val Ok
Check for VRS11-1…
Check for VRS11-1…
INFO: SftyMon_IoHwAbs: toggle check of local and remote sensor successfull
Check for VRS11-1…
Check for VRS11-2…
Check for VRS11-2…
Check for VRS11-2…
Check for VRS11-2…
INFO: NVMCU_SOCPWRCTRL: Programming thermal thresholds done!
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
I:RptrID - 0x810D PsCd - 0xC - PwrCtrl Actshdn Ok
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
Check for VRS10…
I:RptrID - 0x810D PsCd - 0x10 - PwrCtrl Vrs10 NIRQ Chk Ok
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS10 !
Check for VRS11-1…
Check for VRS11-1…
Check for VRS11-1…
I:RptrID - 0x810D PsCd - 0x11 - PwrCtrl Vrs11 NIRQ Chk Ok
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-1!
Check for VRS11-2…
Check for VRS11-2…
Check for VRS11-2…
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-2!
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ continuous monitoring Enabled!
INFO: SftyMon_IoHwAbs: Board Temperature sensor initialized
INFO: NvMCU_SocTMON: toggle check of local and remote sensor successfull
I:RptrID - 0x810C PsCd - 0xB - TMON Toggle Check for Alert & Shutdown Pass
ERROR: MCU_ERRHANDLER: SocVMON : ReportedID - 0x810B ErrorCode - 0x15
I:RptrID - 0x810B PsCd - 0xD - VMON Plausibility pass
INFO: MCU_PLTFPWRMGR: Request NVMCU_SOCTMON_REQ_TOGGLE_CHK Service - finished
ERROR: MCU_PLTFPWRMGR: Request VMON Power-up sequence verification failed! Continue sequence
INFO: MCU_PLTFPWRMGR: Board TMON enabled.
INFO: NvMCU_SocTMON: Soc TMON init complete
INFO: MCU_PLTFPWRMGR: Soc TMON enabled …
INFO: NvMCU_SocTMON: Thermal Monitoring Enabled
I:RptrID - 0x810C PsCd - 0x10 - TMON All thermal events are clear
I:RptrID - 0x810C PsCd - 0x11 - TMON All alert events are clear
INFO: NvMCU_SocTMON: Thermal Alert Trigger not present anymore
I:RptrID - 0x810C PsCd - 0xF - TMON No notification present
Check for VRS10…
Check for VRS10…
Check for VRS10…
INFO: MCU_PLTFPWRMGR: Bootchain selection mode: GPIO
INFO: BtChn_Cfg: Tegra x1 Boot Chain is : A
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN0 set to 0
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN1 set to 0
I:RptrID - 0x810F PsCd - 0x6 - BootchainCfg Dio set success
INFO: NVMCU_SOCPWRCTRL: Tegra reset released
MCU_FOH: MCU FOH : Start Monitoring Called
INFO: MCU_PLTFPWRMGR: Start Network power-up sequence .
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3_AO voltage (3316mV) exceeded threshold (3135mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V8 voltage (810mV) exceeded threshold (759mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3 voltage (3349mV) exceeded threshold (3135mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_1V2 voltage (1212mV) exceeded threshold (1140mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V9 voltage (905mV) exceeded threshold (854mV). Continuing…!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V84 voltage (842mV) exceeded threshold (798mV). Continuing…!
INFO: MCU_PLTFPWRMGR: Request Power-up Ethernet Switch done !
INFO: Network config 0x3: Hyperion 8_1
INFO: RTK_SWITCH: INFO: RTK_SWITCH: INFO: RTK_SWITCH: ERROR: RTK_SWITCH: Condor1: Failed to configure switch
INFO: RTK_SWITCH: INFO: RTK_SWITCH: INFO: RTK_SWITCH: ERROR: RTK_SWITCH: Condor2: Failed to configure switch
INFO: RTK_SWITCH: INFO: RTK_SWITCH: INFO: MRVL_SWITCH: FIR ACTIVE pin disabled (DENY ALL)
INFO: MRVL_SWITCH: Fir switch 88Q5152 init complete
Initialize 88Q222X PHY with SMI address: 3 in Master Mode, Detected Q2221M Package!!!
INFO: PLTFPWRMGR_ETHCTRL: Ethernet switch and Phy initialization completed..
INFO: PLTFPWRMGR_ETHCTRL: Ethernet Link Active
INFO: MCU_PLTFPWRMGR: Request Eth initialization done !
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring enable.
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !
INFO: CmnIf: Wdg Enabled Success!
Power on the system
INFO: MCU_ERRHANDLER: Published Power State: Power-up complete
Init Max load - 100, Average Load - 100
INFO: MCU_SYSSTATEMNGR: State update notification received- 2
INFO : MCU_ISTMGR: IST_DONE pin no monitor time of 2000 ms over.
I:RptrID - 0x810A PsCd - 0xD - ISTManager:IST DONE pin stuck at low not observed.
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started…
MCU_FOH: Switched to FSI_MONITORING_STATE
MCU_FOH: SOC error pin is asserted
ERROR: MCU_ERRHANDLER: SOC error pin is asserted
MCU_FOH: Spi Transmit Started
MCU_FOH: ErrReport: ErrorCode-0x5801 ReporterId-0xe04c Error_Attribute-0x4000080b timestamp-0xde162c8b
MCU_FOH: ErrReport: ErrorCode-0x2807 ReporterId-0xe04c Error_Attribute-0x40000803 timestamp-0xde19d404
MCU_FOH: Periodic Status [0] 0xab [1] 0xcd [250] 0x12 [251] 0x34
ERROR: MCU_SWC_FanControl: count_NoEthFrame_TA value reached to: 101
ERROR: MCU_SWC_FanControl: count_NoEthFrame expired
ERROR: MCU_SWC_FanControl: moving to error state
MCU_FOH: ErrReport: ErrorCode-0x11 ReporterId-0x8225 Error_Attribute-0x10041 timestamp-0x5d91ba4e
