Thor fuse burn
I’m preparing to apply secure boot on our custom board
There’s not yet start
But I’ve seen there’re some people meet some issue
such like Thor with most fuses burned except `SecurityMode`, giving errors - #7 by JerryChang
I’m confusing about “fskp_fuseburn.py tool does NOT support fuse enabled board.
the purpose of this FSKP tool is to burn keys in a factory setting, it currently does not capable of burning a board after PKC/PKCSBK and ODM Key Valid bit in BootSecurityInfo have been set.” by JerryChung’s response
Is that mean I can’t fuse second times if I’ve fuse the “PublicKeyHash”, “PscSecureBootKey”, “OespSecureBootKey” ,“SbSecureBootKey” and “BootSecurityInfo” bit 9 in the first time even if the “SecurityMode” has not been fussed?
hello zax,
that’s correct, you should burning all the fuses you need in a single operation.
