Thor: How to change the UEFI console to UART3_RXD_DEBUG
On my custom board, I connected a device on UART2, UART3_RXD_DEBUG keep output messy code after UEFI boot.
Then use minicom shows UART2, it display UEFI menu.
Apparently, the device output on UART2 was treated as a UEFI menu operation, completely disrupting the UEFI boot process.
So, how can I change the UEFI console to UART3_RXD_DEBUG? and keep UART2 clean.
Hi liu.jialu,
Please share the result of cat /etc/nv_tegra_release on your board.
Do you mean the UART-K? (i.e. serial@810c540000)
yes, it’s serial@810c540000, pins like this:
$ cat /etc/nv_tegra_release
R38 (release), REVISION: 2.0, GCID: 41844464, BOARD: generic, EABI: aarch64, DATE: Fri Aug
22 00:55:42 UTC 2025
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
INSTALL_TYPE=openrm
Could you share the full dmesg and device tree for further check?
full demsg from minicom:
minicom_for_uart.txt (148.2 KB)
device tree:
kernel_tegra264-p4071-0000+p3834-0008-nv.dts.txt (325.2 KB)
Could you try to disable tegra-utc@c4e0000 in device tree source and reflash the board to apply the change?
		tegra-utc@c4e0000 {
			compatible = "nvidia,tegra264-utc";
			reg = <0x00 0xc4e8000 0x00 0x8000 0x00 0xc4e0000 0x00 0x8000>;
			reg-names = "rx\0tx";
			interrupts = <0x00 0x203 0x04>;
			current-speed = <0x1c200>;
			tx-threshold = <0x04>;
			rx-threshold = <0x04>;
-			status = "okay";
+			status = "disabled";
