DRIVE OS Version: 7.0.3
Issue Description:
I developed a new LiDAR plugin with reference to the NVLidar Plugin.
However, the point cloud fails to render when using the sample_lidar_replay tool.
I added debug logs to verify that parseDataBuffer is invoked successfully, and point cloud data is written to the output interface.
How can I further troubleshoot the plugin code?
As I understand it, parseDataBuffer is the final step for the plugin to process point clouds.
Dear @guyuechao ,
Does that mean issue is with recording data or rendering only? Also, could you please attach logs and code as text in topic instead of image.
Dear @SivaRamaKrishnaNV
Thank you for your reply.
The same code logic works correctly for rendering in the build artifact targeting the Orin platform.
Below is the implementation of the parseDataBuffer function.
//###################### Lidar Specific Plugin Functions #########################
dwStatus DemoLidar::parseDataBuffer(dwLidarDecodedPacket* output, const uint64_t hostTimestamp) {
while (m_packetQueue.size() > 0) {
// Get pointer to next packet in queue
rawPacket* p_rawPacket = &(m_packetQueue.front());
InnoDataPacket *pkt = reinterpret_cast<InnoDataPacket *>(&(p_rawPacket->rawData[PAYLOAD_OFFSET]));
if (m_currentIdx == -1) {
m_currentIdx = pkt->idx;
m_frameTimestamp = pkt->common.ts_start_us;
if (pkt->idx != m_currentIdx) {
p_rawPacket = nullptr;
m_packetsPerFrame = m_packetsCounter;
m_packetsCounter = 0;
output->hostTimestamp = hostTimestamp;
// microseconds
output->sensorTimestamp = static_cast<int64_t>(m_frameTimestamp);
output->maxPoints = MAX_POINTS_PER_SPIN;
output->nPoints = m_lidarOutput.n_points;
output->scanComplete = true;
dwLidarPointXYZI* xyzi = const_cast<dwLidarPointXYZI*>(output->pointsXYZI);
dwLidarPointRTHI* rthi = const_cast<dwLidarPointRTHI*>(output->pointsRTHI);
for (size_t i = 0; i < output->nPoints; ++i) {
xyzi[i].x = m_lidarOutput.xyzi[i].x;
xyzi[i].y = m_lidarOutput.xyzi[i].y;
xyzi[i].z = m_lidarOutput.xyzi[i].z;
xyzi[i].intensity = m_lidarOutput.xyzi[i].intensity;
rthi[i].radius = m_lidarOutput.rthi[i].radius;
rthi[i].theta = m_lidarOutput.rthi[i].theta;
rthi[i].phi = m_lidarOutput.rthi[i].phi;
rthi[i].intensity = m_lidarOutput.rthi[i].intensity;
log_info("frame complete, idx=%d, n_points=%d, packets_per_frame=%d", pkt->idx, output->nPoints,
m_packetsPerFrame);
log_info("point: x=%f, y=%f, z=%f, intensity=%f", m_lidarOutput.xyzi[0].x, m_lidarOutput.xyzi[0].y,
m_lidarOutput.xyzi[0].z, m_lidarOutput.xyzi[0].intensity);
std::memset(&m_lidarOutput, 0, sizeof(LidarPacket));
m_lidarOutput.n_points = 0; // ensure n_points is reset
return DW_SUCCESS;
m_packetsCounter++;
// parse data and store in m_lidarOutput
parseDataPacket(pkt);
// Release pointer to packet
// Remove packet from queue
m_packetQueue.pop();
return DW_NOT_READY;
One additional observation to add:
I compared the source code of the sample_lidar_replay tool for Thor and Orin inside the Docker container, located at the path:
/usr/local/driveworks/samples/src/sensors/lidar/lidar_replay/
The left side of the image shows the Thor version, and the right side shows the Orin version.
- Thor: LiDAR data must be stored in
returnData in the DwLidarDecodedReturn format using spherical coordinates. The lidar_replay tool internally converts these to Cartesian coordinates for visualization.
- Orin: Raw XYZ Cartesian coordinate points are stored directly and rendered as point clouds without conversion.
There is a significant discrepancy in how published point cloud data is stored. However, the corresponding Plugin sample code for Thor contains no matching modifications to accommodate this difference.
I populated the returnData based on the original Plugin code, and the content can now display properly.
The code is shown below:
