Jetson thor module + custom board SDK r38.2.
I’m bringing up an Aquantia AQR113C 10G PHY on the MGBE0 interface on a Tegra264 platform. I’ve modified the device tree to remove fixed-link and added the MDIO/PHY nodes using ethernet-phy-ieee802.3-c45.
Current Status:
The Aquantia driver probes successfully and detects the PHY.
The firmware (
.cldfile) is loaded from the filesystem successfully. -
The CRC check passes, indicating the firmware is correctly written to the PHY RAM.
Failure: After the firmware loads and I wait for 2 seconds (added
msleep), thenvethernetdriver fails to attach to the PHY with error-19(-ENODEV).
Here is the dmesg output with my added debug prints:
dmesg.txt (2.0 KB)
aqr113c.diff.txt (4.8 KB)
