Could you please advise? Currently, I’m testing secure boot on my local Thor T4000 board. When I started programming the eFuses, I didn’t set the security mode to 1, but all other settings were programmed normally. The value of boot_security_info is 0x00002228.Under this current state, is there still a way to set the eFuse’s security mode to 1 on this board?
it looks duplicated, let’s keep using Topic 381971 for issue follow up.
Related topics
| THOR Secure Boot Issues | 7 | 183 | September 1, 2026 | |
| Thor with most fuses burned except `SecurityMode`, giving errors | 7 | 229 | March 5, 2026 | |
| Thor fuse burn | 1 | 119 | May 15, 2026 | |
| Thor with fuses burned won't boot past MB1 | 4 | 270 | February 25, 2026 | |
| 技术支持请求:Jetson Thor SecurityMode=1 后无法通过 USB 刷机 | 1 | 148 | July 29, 2026 | |
| Jetson Orin Nano - Exception in EL3 | 11 | 1095 | April 18, 2024 | |
| Secure Boot | 3 | 425 | December 22, 2025 | |
| Orinnx 16G fuse error, boot_security_info 0x000001e0 | 3 | 310 | June 23, 2025 | |
| Jetson Orin NX secure boot: confirm BootSecurityInfo fuse value | 1 | 91 | October 6, 2026 | |
| Pre-burned security fuses coming out inconsistently from the factory | 6 | 128 | November 2, 2026 |
