Hi ,
We are designing a custom carrier board for the Jetson AGX Thor SOM and plan to implement a discrete TPM 2.0 (Trusted Platform Module) for hardware root-of-trust, cryptographic key storage, and secure platform integrity attestation.
Could you please provide guidance and recommendations on the following aspects:
Recommended / Validated TPM 2.0 ICs:
Does NVIDIA officially recommend or have a list of validated discrete TPM 2.0 part numbers for the Thor platform?
(For example, Infineon SLB9670 / SLB9672, STMicroelectronics ST33TPHF20SPI, or Nuvoton NPCT75x series?) -
Interface & Hardware Guidelines:
- Is SPI (TCG PC Client TPM Profile over SPI) the preferred and fully supported interface?
- What are the recommended SPI clock frequencies, chip-select timing constraints, and GPIO interrupt requirements for the TPM circuit?
Software & JetPack 7.x Support:
Under JetPack 7.2.1 / Jetson Linux r39.2.1:- Are standard Linux TPM drivers (e.g.,
CONFIG_TCG_TPM=y,CONFIG_TCG_TIS_SPI=y) enabled out-of-the-box, or is kernel rebuilding required? - Is the external TPM recognized and utilized by the EDK2 UEFI bootloader for Measured Boot and PCR extension prior to Linux kernel launch?
Reference Implementation:
Does NVIDIA provide a reference schematic snippet or device-tree overlay (.dts/.dtsi) for connecting an external SPI TPM to the Thor module?
Thank you in advance for your technical guidance!
Best regards,
