请问SPI3的驱动能力默认是多少,最大能调到多少
从pinmux来看,是有drive0和1两个档位,
请问驱动能力都是多少呢?
Hi zhangwenjing11,
Are you using the devkit or custom board for Thor?
The drive strength is not configured in pinmux spreadsheet.
Drive 0/1 in the table means the default(after boot) state High/Low for the GPIO/Output pins.
May I know about your use case? Do you want to use those pins as GPIO or SPI?
Hi, KevinFFF:
=> custom board
=> R39.2
=> SPI
For SPI3 on Thor, the pinmux exposes two drive settings through DRV_TYPE in Column AY: normal (Disable, 1x driver) and high (Enable, 2x driver).
The pinmux sheet does not provide a direct mA value for these two modes.
If the SPI frequency is above 25 MHz, DRV_TYPE is recommended to be set to Enable (2x) to improve signal integrity and reliability.
Hi, KevinFFF:
Get it.
Thank you for your reply and suggestion.
