Thor(t4000)系统ubunut24.04,压测t4000冷启动压测27次后,系统启动失败一次
thor(t4000)系统ubunut24.04,压测t4000冷启动压测27次后,系统启动失败一次,重新上电可以正常启动;系统启动失败log如截图,完成log见N4ColdBootFail.txt,请问是什么问题?
N4ColdBootFail.txt (284.7 KB)
I saw multiple problems in the log. Do you have monitors connected when you reproduce the issue?
我让测试的弄一下
No, I am not asking you to connect a monitor.
Merely asking if there was monitor connected when you do the test. Yes or no question only.
yes,连接了显示器
Please remove it and do the test again.
不接显示器压测,累计压测2333次,没有复现问题
Are you using jp7.1?
38.4.0
please upgrade to jp7.2. This one looks to be the known issue fixed already.
目前用的还是38.4.0 用了typeC转dp线 出现了 插拔显示器端DP接口,存在白屏卡顿
Could you try with newer JetPack? Thanks
