Thor T4000 USB3
DRIVE OS Version: jetpack7.1
Issue Description: U盘连接接口,未识别到USB3.0信号,使用的是UPHY0_L1,查看手册默认是开启的
Moved to Jetson AGX Thor forum
Sorry for the late response.
Would you mind to share the cause and how to fix it? Thanks
Could you please provide any update for this topic?
我们尝试修改usb2-companion的值,修改后USB(P1)正常了,但是USB(P2)识别不到3.0信号,另外UPHY0我们配置的是6,请问这是什么原因呢?是否有相关的补丁?
There is no suggestion if you just give out info like this.
You better sharing the whole block diagram of how your USB design is.
你好,原理图:
识别不到USB3.0的是A23与A22这组
then please share your current device tree.
padctl@a808680000 {
            status = "okay";
            pads {
                usb2 {
                    lanes {
                        usb2-0 {
                            status = "okay";
                        usb2-1 {
                            status = "okay";
                        usb2-2 {
                            status = "okay";
                        usb2-3 {
                            status = "okay";
                usb3 {
                    lanes {
                        usb3-0 {
                            status = "okay";
                        usb3-1 {
                            status = "okay";
                        usb3-2 {
                            status = "okay";
            ports {
                usb2-0 {
                    mode = "otg";
                    usb-role-switch;
                    role-switch-default-mode = "peripheral";
                    status = "okay";
                usb2-1 {
                    mode = "host";
                    status = "okay";
                usb2-2 {
                    mode = "host";
                    status = "okay";
                usb2-3 {
                    mode = "host";
                    status = "okay";
                usb3-0 {
                    nvidia,usb2-companion = <1>;
                    maximum-speed = "super-speed";
                    status = "okay";
                usb3-1 {
                    nvidia,usb2-companion = <0>;
                    status = "okay";
                usb3-2 {
                    nvidia,usb2-companion = <3>;
                    status = "okay";
        usb@a808670000 {
            phys = <&{/bus@0/padctl@a808680000/pads/usb2/lanes/usb2-0}>,
                <&{/bus@0/padctl@a808680000/pads/usb3/lanes/usb3-1}>;
            phy-names = "usb2-0", "usb3-1";
            status = "okay";
        usb@a80aa10000 {
            interrupts-extended = <&gic 0 952 IRQ_TYPE_LEVEL_HIGH>,
                <&gic 2 0 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 79 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 80 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 82 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 83 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 84 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 85 IRQ_TYPE_LEVEL_HIGH>,
                <&pmc 86 IRQ_TYPE_LEVEL_HIGH>;
            interrupt-names = "xhci", "mbox",
                    "wake0", "wake1", "wake2", "wake3",
                    "wake4", "wake5", "wake6";
                <&{/bus@0/padctl@a808680000/pads/usb2/lanes/usb2-1}>,
                <&{/bus@0/padctl@a808680000/pads/usb2/lanes/usb2-2}>,
                <&{/bus@0/padctl@a808680000/pads/usb2/lanes/usb2-3}>,
                <&{/bus@0/padctl@a808680000/pads/usb3/lanes/usb3-0}>,
                <&{/bus@0/padctl@a808680000/pads/usb3/lanes/usb3-1}>,
                <&{/bus@0/padctl@a808680000/pads/usb3/lanes/usb3-2}>;
            phy-names = "usb2-0", "usb2-1", "usb2-2", "usb2-3", "usb3-0", "usb3-1", "usb3-2";
            status = "okay";
以上是DTB部分,谢谢
如果我對你線路圖的理解沒有錯
A23/A22是USB3-1.
C10/C11是USB2-1.
那麼device tree很明顯寫錯了
我该怎么修改呢?
                usb3-0 {
                    status = "okay";
                usb3-1 {
                    status = "okay";
        usb@a808670000 {
            status = "okay";
以上都是錯的.
麻烦提供一下具体的修改内容,谢谢
還是請您先讀一下文件吧
能理解背後的原理總比我直接分享答案好.
我理解的是你usb2-1/usb3-1是一組的 但你的device tree明顯不是這樣寫
