I am trying to flash a Jetson Thor T5000 module on our custom carrier board using JetPack 7.2.1 (L4T R39.2.1).
However, flashing fails during the MB1 initialization stage due to an I2C timeout.
1. Issue Description
The following error occurs during flashing:
a) UART consol
[0001.145] I> Task: Pinmux init
[0001.148] I> Task: Prod config init
[0001.151] W> PROD_CONFIG: controller prod table is empty in MB1 BCT.
[0001.157] I> Task: Pad voltage init
[0001.160] I> Task: Prod init
[0001.163] I> Task: Common rail init
[0001.169] E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[0001.174] E> I2C: Could not write 0 bytes to slave: 0x0098 with repeat start false.
[0001.182] E> I2C_DEV: Could not write data of size 1 to slave 0x98 at 0x00000009 via instance 5.
[0001.191] C> NONE: Failed to update reg address 0x09 of slave 0x98 in i2c block :0 in pad voltage config table.
[0001.201] E> PMIC_CONFIG: Failed to initialize Rail: Thermal configuration.
[0001.207] C> Task 0x36 failed (err: 0x57573d02)
[0001.211] E> Top caller module: PMIC_CONFIG, error module: PMIC_CONFIG, reason: 0x02, aux_info: 0x3d
[0001.220] C> Boot Info Table status dump :
00111111011110011111100111111111111111111011111111111100
b) Host PC
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/025 --chip 0x26 --pollbl
cwd = /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/flash_workspace/rcm-flash
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : BL: version 0.25.1.1-t264-75019003-d9a316ff last_boot_error: 0[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/025 --download bct_mem membct_6_zerosign.bct
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : Sending bct_mem[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/025 --download blob ./rcm_blob.bin
[flash_bsp_jetson-t264_die0]: [executeShellCommand(171)] : shell command – /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/025 --download blob ./rcm_blob.bin failed
[flash_bsp_jetson-t264_die0]: [executeShellCommand(173)] : Output: Sending blob
ERROR: might be timeout in USB write.[flash_bsp_jetson-t264_die0]: [executeShellCommand(175)] : Return code: 3
[flash_bsp_jetson-t264_die0]: [executeShellCommand(177)] : stdout: b’Sending blob\nERROR: might be timeout in USB write.\n’
[flash_bsp_jetson-t264_die0]: [executeShellCommand(179)] : stderr: None
[flash_bsp_jetson-t264_die0]: [sendRcmCommand(773)] : Unable to execute tegrarcm command – /home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/025 --download blob ./rcm_blob.bin
File “/home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/flash_bsp_images.py”, line 113, in flash_bsp_active
bootburnThor.BootRCM(“rcm-flash”, binaryLocationPath)
File “/home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn_t264_py/bootburn_thor.py”, line 1300, in BootRCM
self.sendRcmCommand("–download blob " + blob)
File “/home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_lib.py”, line 774, in sendRcmCommand
AbnormalTermination(“TEGRARCM – Unable to execute command”, nverror.NvError_TegraRcmError)
File “/home/nyx/work/thor/working/r39.2.1/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/bootburn/../bootburn_t264_py/flashtools_nverror.py”, line 263, in AbnormalTermination
raise OSError(errorCode)
OSError: 43
For debugging purposes, we temporarily removed the TMP451 configuration. However, the error then occurred at another I2C slave address (0x78) on the same I2C controller (instance 5).
2. What We Have Checked
- The TMP451 and the device at slave address
0x78appear to use the same I2C controller (instance These devices are configured in NVIDIA’s original MB1 PMIC BCT. - USB download can be completed using both the original EVK BSP and our modified BSP on the EVK.
Are there any recommended debugging steps for an MB1 PMIC_CONFIG failure ?
