Hello, The design guides for the Thor T5000 recommend 4.2-mm length standoffs for mounting the carrier board to the module. We’ve been able to find 4.2-mm L standoffs in nylon but we want to use steel standoffs. Any recommendations? 4.2-mm L steel standoffs seem very hard to order.
We do not have any recommendations for now. If this changes, we will update.
Thank you. Hopefully if nVidia does make standoff recommendations they should be added to the “NVIDIA Jetson Thor Series Supported Components List” document, Officially this doc is called “Jetson_Thor_Series_SCL_DA-12429-001_v1.0.pdf”
