[Thor]Thor Dev Kit USB3 KdiskMark Speed
Hi
We tested the P40 USB disk by running KDiskMark on the Thor Dev Kit. The read speed was 993-1000 MB/s, while the write speed was only around 500 MB/s. Is this normal?
Please check if you can reproduce the issue on developer kit with Jetpack 7.2.1(r39.2.1)? If yes, please share the command. We will set up developer kit and check.
We are using Jetpack 7.2.1, but we found that USB4 devices do not exhibit low write speeds during USB interface testing.
We will verify it again, and if there are any issues, I will update it accordingly.
