Hi NVIDIA
When testing JETSON Thor Carrier Board, we found that the speed of USB3 will slow down for a short period of time after Suspend wake-up, and in the worst case, it will slow down by 10%. After waiting for 2-5 minutes, the speed will return to normal.
I tested Thor Dev Kit and there is also a probability of Suspend dropping speed, which is similar to our Carrier Board. Is this behavior normal?
The speed measurement device we use is P40, and the speed measurement software is KdiskMark
Will it also show if I try with some USB SSD and with benchmark tool ?
Yes, you can give it a try. We are using a 10G USB storage device. Under the system, we run KdiskMark with SEQ1M Q8T1, record the data, then enter Suspend mode. After waiting 1~2 minutes to wake up, we immediately run Q8T1 again and compare the data. In my current tests of 5 runs, there was one instance of speed reduction.
We try to run the performance test with the Kingston SSD on our side but could not reproduce the issue.
