Thor with fuses burned won't boot past MB1
We’re using a Thor with a Forecr DSBOARD-THRMAX.
We followed the procedure here to create the fuse blob and then burned the fuses with fskp_fuseburn.py:
cd ~/nvidia/nvidia_sdk/JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/l4t/tools/flashtools/fuseburn
sudo ./fskp_fuseburn.py \
    --board-spec thor-agx-board-spec.txt \
    --prebuilt ./out \
    --chip 0x26 \
    --board ~/nvidia/nvidia_sdk/JetPack_7.1_Linux_JETSON_AGX_THOR_TARGETS/Linux_for_Tegra/jetson-agx-thor-devkit.conf
The UART showed no errors. I’ve used flash.sh to read the fuse values back out
sudo ./flash.sh \
    --read-info \
    -u ~/security_keys/pkc_keylist.xml \
    -v ~/security_keys/sbk.key \
    jetson-agx-thor-devkit \
    internal
and they all match our fuse_config.xml, shown here with the secrets removed. We followed the fuse spec and reference fuse config file to make this.
<genericfuse MagicId="0x45535546" version="1.0.0">
    <fuse name="ArmJtagDisable" size="4" value="0x1" />
    <fuse name="DebugAuthentication" size="4" value="0x1F" />
    <fuse name="OdmLock" size="4" value="0xF" />
    <fuse name="OptInEnable" size="4" value="0x1" />
    <fuse name="PublicKeyHash" size="64" value="(secret)" />
    <fuse name="PscSecureBootKey" size="32" value="(secret)" />
    <fuse name="PscOemKdk0" size="32" value="(secret)" />
    <fuse name="PscOemKdk1" size="32" value="(secret)" />
    <fuse name="BootSecurityInfo" size="4" value="0x628" />
    <fuse name="SecurityMode" size="4" value="0x1" />
</genericfuse>
Next we tried to flash it with:
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" \
    ./tools/kernel_flash/l4t_initrd_flash.sh \
    -i "~/security_keys/disk_encryption.key" \
    -u "~/security_keys/pkc_keylist.xml" \
    -v "~/security_keys/sbk.key" \
    --uefi-keys "~/security_keys/uefi_keys.conf" \
    --showlogs \
    --network usb0 \
    internal
but this is where we get stuck.
When it boots up during the flash process, the boot flow gets through MB1 and seems to crash right when MB1 tries to hand off to MB2. This is what the UART shows when it crashes (log cuts off at the dot) (full logs attached):
[0005.758] I> Task: Release CARVEOUT_TEMP_PSCBL
[0005.762] I> Task: Load MB2/Applet/FSKP/MB2RF
[0005.766] I> Loading MB2
[0005.768] I> Slot: 0
[0005.770] I> Binary[10] block-167772160 (partition size: 0xc0000)
[0005.776] I> Binary name: MB2
[0005.779] I> Size of crypto header is 8192
[0005.783] I> Size of crypto header is 8192
[0005.787] I> BCH of MB2 read from storage
[0005.791] I> MB2 header integrity check is success
[0005.795] I> Binary magic in BCH component 0 is MB2B
[0005.800] I> component binary type is 10
[0005.804] I> Size of crypto header is 8192
[0005.809] I> MB2 binary is read from storage
[0005.813] I> MB2 binary integrity check is success
[0005.
For reference, this is what a successful boot is supposed to look like, which we logged on the same Thor on a non-secure boot before we burned any fuses:
[0005.627] I> MB2 binary is read from storage
[0005.631] I> MB2 binary integrity check is success
[0005.635] I> Task: Initialize MB2 page table
[0005.638] I> Task: Dram ecc test
[0005.641] I> Task: Map CCPLEX SHARED carveout
[0005.646] I> Task: Ack HPSE mbox
[0005.649] I> Task: Ack SB mbox
[0005.651] I> Task: Misc NV security settings
[0005.656] I> Task: Runtime IST init
[0005.659] I> Task: Disable/Reload WDT
[0005.662] I> Task: Initialize MB2 params
[0005.666] I> Task: Prepare MB2 params
Any ideas what could be wrong?
jetson_log_serial_mb2_fail_isolated_2026-02-18_10-25AM.txt (17.9 KB)
hello chris649,
according to developer guide, Prepare EKB.
you’ll need to update EKS image since you’ve KDK1 fuse burned.
please download Driver Package (BSP) Sources for the nvidia-jetson-optee-source.tbz2 package, you may refer to sample script to re-generate EKS image (eks_t264.img) for confirmation.
for instance, $public_sources/r38.4.0/Linux_for_Tegra/source/atf_and_optee/optee/samples/hwkey-agent/host/tool/gen_ekb/example.sh
We’ve mostly done that already. Here’s the command we used, the same as what we did for the Jetson Orin but using JetPack 7.1:
cd ~/jetpack_7_1_bsp_sources/Linux_for_Tegra/source/optee/samples/hwkey-agent/host/tool/gen_ekb/
python3 gen_ekb.py \
    -chip t264 \
    -oem_kdk1_key ~/security_keys/oem_kdk1.key \
    -in_sym_key ~/security_keys/uefi_payload_encryption.key \
    -in_sym_key2 ~/security_keys/disk_encryption.key \
    -in_auth_key ~/security_keys/uefi_variable_authentication.key \
    -out ~/security_keys/eks_t264.img
However, now that I look at it, the -in_sym_key might be problematic because the Thor doesn’t support UEFI payload encryption. So I dropped -in_sym_key and generated eks_t264.img again but with the same result.
It doesn’t make sense that the failure is a security related one, wouldn’t the UART at least say so or stop gracefully if it detected a security failure? Right now the Thor is crashing in the middle of a print statement, at the decimal point [0005., which seems like an unhandled failure.
hello chris649,
did you burn OespSecureBootKey and SbSecureBootKey as well?
note, OespSecureBootKey and SbSecureBootKey must be burned with the same value of PscSecureBootKey. otherwise system fails to boot.
please see-also developer guide, Prepare an SBK key.
let me re-cap as below..
Caution
For the Jetson Thor series, the three SBK fuses, PscSecureBootKey, OespSecureBootKey and SbSecureBootKey, must be programmed with the same value.
