THPS12.exe crashes
Tony Hawk Pro Skater 1&2. It’s stable when I boot into Windows 10 on a SSD. When I run from Linux/Steam I get unpredictable crashes. When it crashes, the screen stays on the last frame, and they keyboard locks up where the numlock/capslock have no effect on keyboard LED. Maybe that’s a clue. I am able to ssh in and shutdown. I am able to play on Windows, so not a huge deal. Happens with 565.77 and 570.124.04.
Any debug advice welcome, not sure if these crashes are related. It didn’t look like today’s crash left any report.
Mar 14 18:19:39 kernel: [ 6397.800351] NVRM: GPU at PCI:0000:01:00: GPU-727131e1-c818-f5db-a239-534078700cbb
Mar 14 18:19:39 kernel: [ 6397.800367] NVRM: GPU Board Serial Number: 0422815001998
Mar 14 18:19:39 kernel: [ 6397.800373] NVRM: Xid (PCI:0000:01:00): 8, pid=27067, name=THPS12.exe, Channel 0000002b
Mar 15 04:23:13 kernel: [ 3131.560958] NVRM: GPU at PCI:0000:01:00: GPU-727131e1-c818-f5db-a239-534078700cbb
Mar 15 04:23:13 kernel: [ 3131.560975] NVRM: GPU Board Serial Number: 0422815001998
Mar 15 04:23:13 kernel: [ 3131.560980] NVRM: Xid (PCI:0000:01:00): 8, pid=23072, name=THPS12.exe, Channel 0000003b
This appears in the game log:
BITDEMON MEMORY LEAKS DETECTED
32 Bytes leaked in 1 allocation(s)
pid 12647 != 12646, skipping destruction (fork without exec?)
I came across this that might help, on my system I have to manually do a couple of the steps:
Will update.
No dice. At the very least it looks like i will have to rebuild some/all of my xorg packages, probably a more recent version, to see if I get this working if it will help the crashing. This might take a bit of elbow grease on this distro(LFS), so it might be awhile before I attempt it.
xrandr --output HDMI-0 --set “PRIME Synchronization” 0
gives a failed request message.
Do I need to run the nvidia installer script while “modprobe nvidia-drm modeset=1” is active? Because right now if I launch the install script after modprobe nvidia-drm modeset=1 the screen goes black and I can’t exit. I think it is running, I just can’t see it because of a missing font or unicode or something. -nogui doesn’t help. Esc doesn’t exit. Can’t switch to other virtual terminals. I have to reboot. I added modprobe nvidia-drm modeset=1 to modprobe.d, but since the install script didn’t work with it I removed it and do it manually.
So in trying to get Prime working, I realized I don’t have an integrated graphics chip on this system and I only use one monitor, so this might not even be applicable in my situation, but sometimes even if that is so, it might be beneficial for me to get it “working” as much as possible. Right now Xorg says my xserver doesn’t support Prime render offload. So maybe I have gone as far as I can go. I spent yesterday re-configuring, re-building, and re-installing llvm, xserver, mesa, gbm, mesa-demos, xrandr, wayland, meson, and others I can’t remember at the moment multiple times. I did make some progress. I manually
rmmod nvidia-drm
xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 570.124.04
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "InputDevice"
    # generated from data in "/etc/sysconfig/mouse"
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "IMPS/2"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "yes"
    Option         "ZAxisMapping" "4 5"
EndSection
    # generated from default
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "LG Electronics LG QHD"
    HorizSync       30.0 - 230.0
    VertRefresh     50.0 - 144.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "NVIDIA GeForce GTX TITAN X"
    BusID          "PCI:1:0:0"
    Option         "AllowEmptyInitialConfiguration"
EndSection
Section "Files"
    FontPath        "/usr/share/fonts/X11/75dpi"
    FontPath        "/usr/share/fonts/X11/100dpi"
    FontPath        "/usr/share/fonts/X11/OTF"
    FontPath        "/usr/share/fonts/X11/Speedo"
    FontPath        "/usr/share/fonts/X11/TTF"
    FontPath        "/usr/share/fonts/X11/Type1"
    FontPath        "/usr/share/fonts/X11/cyrillic"
    FontPath        "/usr/share/fonts/X11/encodings"
    FontPath        "/usr/share/fonts/X11/misc"
    FontPath        "/usr/share/fonts/microsoft"
    FontPath        "/usr/share/fonts/address_missing_unicode/Symbola"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "nvidia-auto-select +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "ServerFlags"
    Option         "IgnoreABI" "1"
EndSection
Xorg:
[ 2065.856] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 2066.115] (II) GLX: Another vendor is already registered for screen 0
eglinfo works better now, but it does also produce this:
Wayland platform:
eglinfo: eglInitialize failed
eglgears_wayland reports:
EGLUT: failed to initialize native display
dmesg grep nvidia:
[    6.855304] input: HDA NVidia HDMI as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card1/input3
[    6.856123] input: HDA NVidia HDMI as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card1/input4
[    6.892554]   #1: HDA NVidia at 0xfa080000 irq 47
[   10.917120] nvidia: loading out-of-tree module taints kernel.
[   10.917855] nvidia: module license 'NVIDIA' taints kernel.
[   10.919238] nvidia: module license taints kernel.
[   11.877594] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[   11.881648] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[   12.082568] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  570.124.04  Tue Feb 25 04:12:12 UTC 2025
[   12.149118] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  570.124.04  Tue Feb 25 03:39:21 UTC 2025
[   12.160856] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   12.161664] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
[ 1857.571761] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 1862.335464] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 1863.033958] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
[ 1863.034886] nvidia 0000:01:00.0: vgaarb: deactivate vga console
[ 1863.096667] fbcon: nvidia-drmdrmfb (fb0) is primary device
[ 1863.154446] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
xrandr -v
xrandr program version 1.5.3
Server reports RandR version 1.6
So yesterday was kinda nuts so I am just going to boot into Windows for a bit. Any help appreciated.
nvidia-bug-report.log.gz (835.0 KB)
Also, there is a lot of tearing when watching videos now, without moving the window around or anything, just sitting there playing.
Actually there is a lot of tearing all the time. Even bringing up the menu in fluxbox tears. Moving small windows tear.
Just came back to an unresponsive system. Similar to when it crashes on certain windows games. Keyboard worked, could not change modes or terminals, but I was able to exit x with ctrl-alt-backspace if it was still running and reboot with ctrl-alt-delete.
I refrain from modprobing nvidia-drm with a modeset=1, and went back to my tried and true xorg.conf and it seems my system is more or less back to normal. I will still try to figure this out, but will take a break for a bit.
Made some good progress. Built and installed many new packages. Rebuilt and reinstalled many existing packages. I am now able to run eglgears_wayland via weston which isn’t ideal, but definitely a good starting point and I might leave things here if the few steam/wine games that crash stop crashing if I fixed that along the way of getting this going.
I am guessing prime is of no use on my system, but will research further.
$ eglinfo
EGL client extensions string:
    EGL_EXT_platform_base EGL_EXT_device_base EGL_EXT_device_enumeration
    EGL_EXT_device_query EGL_KHR_client_get_all_proc_addresses
    EGL_EXT_client_extensions EGL_KHR_debug EGL_KHR_platform_x11
    EGL_EXT_platform_x11 EGL_EXT_platform_device
    EGL_MESA_platform_surfaceless EGL_EXT_explicit_device
    EGL_KHR_platform_wayland EGL_EXT_platform_wayland
    EGL_KHR_platform_gbm EGL_MESA_platform_gbm EGL_MESA_platform_xcb
GBM platform:
EGL API version: 1.5
EGL vendor string: NVIDIA
EGL version string: 1.5
EGL client APIs: OpenGL_ES OpenGL
EGL extensions string:
    EGL_ANDROID_native_fence_sync EGL_EXT_buffer_age EGL_EXT_client_sync
    EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import
    EGL_EXT_image_dma_buf_import_modifiers EGL_MESA_image_dma_buf_export
    EGL_EXT_output_base EGL_EXT_output_drm EGL_EXT_protected_content
    EGL_EXT_stream_consumer_egloutput EGL_EXT_stream_acquire_mode
    EGL_EXT_sync_reuse EGL_IMG_context_priority EGL_KHR_config_attribs
    EGL_KHR_create_context_no_error EGL_KHR_context_flush_control
    EGL_KHR_create_context EGL_KHR_fence_sync
    EGL_KHR_get_all_proc_addresses EGL_KHR_partial_update
    EGL_KHR_swap_buffers_with_damage EGL_KHR_no_config_context
    EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image
    EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image
    EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base
    EGL_KHR_reusable_sync EGL_KHR_stream EGL_KHR_stream_attrib
    EGL_KHR_stream_consumer_gltexture EGL_KHR_stream_cross_process_fd
    EGL_KHR_stream_fifo EGL_KHR_stream_producer_eglsurface
    EGL_KHR_surfaceless_context EGL_KHR_wait_sync EGL_NV_nvrm_fence_sync
    EGL_NV_quadruple_buffer EGL_NV_stream_consumer_eglimage
    EGL_NV_stream_cross_display EGL_NV_stream_cross_object
    EGL_NV_stream_cross_process EGL_NV_stream_cross_system
    EGL_NV_stream_dma EGL_NV_stream_flush EGL_NV_stream_metadata
    EGL_NV_stream_remote EGL_NV_stream_reset EGL_NV_stream_socket
    EGL_NV_stream_socket_inet EGL_NV_stream_socket_unix
    EGL_NV_stream_sync EGL_NV_stream_fifo_next
    EGL_NV_stream_fifo_synchronous EGL_NV_stream_consumer_gltexture_yuv
    EGL_NV_stream_attrib EGL_NV_stream_origin EGL_NV_system_time
    EGL_NV_output_drm_flip_event EGL_NV_triple_buffer
    EGL_NV_robustness_video_memory_purge EGL_EXT_present_opaque
    EGL_WL_bind_wayland_display EGL_WL_wayland_eglstream
Configurations:
     bf lv colorbuffer dp st  ms    vis   cav bi  renderable  supported
  id sz  l  r  g  b  a th cl ns b    id   eat nd gl es es2 vg surfaces
0x01 32  0  8  8  8  8 24  8  0 0 0x34325241--         y  y  y     win,pb,str
0x02 32  0  8  8  8  8 24  0  0 0 0x34325241--         y  y  y     win,pb,str
0x03 32  0  8  8  8  8  0  8  0 0 0x34325241--         y  y  y     win,pb,str
0x04 32  0  8  8  8  8  0  0  0 0 0x34325241--         y  y  y     win,pb,str
0x05 32  0  8  8  8  8 24  8  2 1 0x34325241--         y  y  y     win,pb,str
0x06 32  0  8  8  8  8 24  0  2 1 0x34325241--         y  y  y     win,pb,str
0x07 32  0  8  8  8  8  0  8  2 1 0x34325241--         y  y  y     win,pb,str
0x08 32  0  8  8  8  8  0  0  2 1 0x34325241--         y  y  y     win,pb,str
0x09 32  0  8  8  8  8 24  8  4 1 0x34325241--         y  y  y     win,pb,str
0x0a 32  0  8  8  8  8 24  8  4 1 0x34325241--         y  y  y     win,pb,str
0x0b 32  0  8  8  8  8 24  0  4 1 0x34325241--         y  y  y     win,pb,str
0x0c 32  0  8  8  8  8 24  0  4 1 0x34325241--         y  y  y     win,pb,str
0x0d 32  0  8  8  8  8  0  8  4 1 0x34325241--         y  y  y     win,pb,str
0x0e 32  0  8  8  8  8  0  8  4 1 0x34325241--         y  y  y     win,pb,str
0x0f 32  0  8  8  8  8  0  0  4 1 0x34325241--         y  y  y     win,pb,str
0x10 32  0  8  8  8  8  0  0  4 1 0x34325241--         y  y  y     win,pb,str
0x11 32  0  8  8  8  8 24  8  8 1 0x34325241--         y  y  y     win,pb,str
0x12 32  0  8  8  8  8 24  0  8 1 0x34325241--         y  y  y     win,pb,str
0x13 32  0  8  8  8  8  0  8  8 1 0x34325241--         y  y  y     win,pb,str
0x14 32  0  8  8  8  8  0  0  8 1 0x34325241--         y  y  y     win,pb,str
0x15 24  0  8  8  8  0 24  8  0 0 0x34325258--         y  y  y     win,pb,str
0x16 24  0  8  8  8  0 24  0  0 0 0x34325258--         y  y  y     win,pb,str
0x17 24  0  8  8  8  0  0  8  0 0 0x34325258--         y  y  y     win,pb,str
0x18 24  0  8  8  8  0  0  0  0 0 0x34325258--         y  y  y     win,pb,str
0x19 24  0  8  8  8  0 24  8  2 1 0x34325258--         y  y  y     win,pb,str
0x1a 24  0  8  8  8  0 24  0  2 1 0x34325258--         y  y  y     win,pb,str
0x1b 24  0  8  8  8  0  0  8  2 1 0x34325258--         y  y  y     win,pb,str
0x1c 24  0  8  8  8  0  0  0  2 1 0x34325258--         y  y  y     win,pb,str
0x1d 24  0  8  8  8  0 24  8  4 1 0x34325258--         y  y  y     win,pb,str
0x1e 24  0  8  8  8  0 24  8  4 1 0x34325258--         y  y  y     win,pb,str
0x1f 24  0  8  8  8  0 24  0  4 1 0x34325258--         y  y  y     win,pb,str
0x20 24  0  8  8  8  0 24  0  4 1 0x34325258--         y  y  y     win,pb,str
0x21 24  0  8  8  8  0  0  8  4 1 0x34325258--         y  y  y     win,pb,str
0x22 24  0  8  8  8  0  0  8  4 1 0x34325258--         y  y  y     win,pb,str
0x23 24  0  8  8  8  0  0  0  4 1 0x34325258--         y  y  y     win,pb,str
0x24 24  0  8  8  8  0  0  0  4 1 0x34325258--         y  y  y     win,pb,str
0x25 24  0  8  8  8  0 24  8  8 1 0x34325258--         y  y  y     win,pb,str
0x26 24  0  8  8  8  0 24  0  8 1 0x34325258--         y  y  y     win,pb,str
0x27 24  0  8  8  8  0  0  8  8 1 0x34325258--         y  y  y     win,pb,str
0x28 24  0  8  8  8  0  0  0  8 1 0x34325258--         y  y  y     win,pb,str
0x29 16  0  5  6  5  0 24  8  0 0 0x36314752--         y  y  y     win,pb,str
0x2a 16  0  5  6  5  0 24  0  0 0 0x36314752--         y  y  y     win,pb,str
0x2b 16  0  5  6  5  0 16  0  0 0 0x36314752--         y  y  y     win,pb,str
0x2c 16  0  5  6  5  0  0  8  0 0 0x36314752--         y  y  y     win,pb,str
0x2d 16  0  5  6  5  0  0  0  0 0 0x36314752--         y  y  y     win,pb,str
0x2e 16  0  5  6  5  0 24  8  2 1 0x36314752--         y  y  y     win,pb,str
0x2f 16  0  5  6  5  0 24  0  2 1 0x36314752--         y  y  y     win,pb,str
0x30 16  0  5  6  5  0 16  0  2 1 0x36314752--         y  y  y     win,pb,str
0x31 16  0  5  6  5  0  0  8  2 1 0x36314752--         y  y  y     win,pb,str
0x32 16  0  5  6  5  0  0  0  2 1 0x36314752--         y  y  y     win,pb,str
0x33 16  0  5  6  5  0 24  8  4 1 0x36314752--         y  y  y     win,pb,str
0x34 16  0  5  6  5  0 24  8  4 1 0x36314752--         y  y  y     win,pb,str
0x35 16  0  5  6  5  0 24  0  4 1 0x36314752--         y  y  y     win,pb,str
0x36 16  0  5  6  5  0 24  0  4 1 0x36314752--         y  y  y     win,pb,str
0x37 16  0  5  6  5  0 16  0  4 1 0x36314752--         y  y  y     win,pb,str
0x38 16  0  5  6  5  0 16  0  4 1 0x36314752--         y  y  y     win,pb,str
0x39 16  0  5  6  5  0  0  8  4 1 0x36314752--         y  y  y     win,pb,str
0x3a 16  0  5  6  5  0  0  8  4 1 0x36314752--         y  y  y     win,pb,str
0x3b 16  0  5  6  5  0  0  0  4 1 0x36314752--         y  y  y     win,pb,str
0x3c 16  0  5  6  5  0  0  0  4 1 0x36314752--         y  y  y     win,pb,str
0x3d 16  0  5  6  5  0 24  8  8 1 0x36314752--         y  y  y     win,pb,str
0x3e 16  0  5  6  5  0 24  0  8 1 0x36314752--         y  y  y     win,pb,str
0x3f 16  0  5  6  5  0 16  0  8 1 0x36314752--         y  y  y     win,pb,str
0x40 16  0  5  6  5  0  0  8  8 1 0x36314752--         y  y  y     win,pb,str
0x41 16  0  5  6  5  0  0  0  8 1 0x36314752--         y  y  y     win,pb,str
Wayland platform:
Configurations:
0x01 32  0  8  8  8  8 24  8  0 0 0x00--         y  y  y     win,pb,str
0x02 32  0  8  8  8  8 24  0  0 0 0x00--         y  y  y     win,pb,str
0x03 32  0  8  8  8  8  0  8  0 0 0x00--         y  y  y     win,pb,str
0x04 32  0  8  8  8  8  0  0  0 0 0x00--         y  y  y     win,pb,str
0x05 32  0  8  8  8  8 24  8  2 1 0x00--         y  y  y     win,pb,str
0x06 32  0  8  8  8  8 24  0  2 1 0x00--         y  y  y     win,pb,str
0x07 32  0  8  8  8  8  0  8  2 1 0x00--         y  y  y     win,pb,str
0x08 32  0  8  8  8  8  0  0  2 1 0x00--         y  y  y     win,pb,str
0x09 32  0  8  8  8  8 24  8  4 1 0x00--         y  y  y     win,pb,str
0x0a 32  0  8  8  8  8 24  8  4 1 0x00--         y  y  y     win,pb,str
0x0b 32  0  8  8  8  8 24  0  4 1 0x00--         y  y  y     win,pb,str
0x0c 32  0  8  8  8  8 24  0  4 1 0x00--         y  y  y     win,pb,str
0x0d 32  0  8  8  8  8  0  8  4 1 0x00--         y  y  y     win,pb,str
0x0e 32  0  8  8  8  8  0  8  4 1 0x00--         y  y  y     win,pb,str
0x0f 32  0  8  8  8  8  0  0  4 1 0x00--         y  y  y     win,pb,str
0x10 32  0  8  8  8  8  0  0  4 1 0x00--         y  y  y     win,pb,str
0x11 32  0  8  8  8  8 24  8  8 1 0x00--         y  y  y     win,pb,str
0x12 32  0  8  8  8  8 24  0  8 1 0x00--         y  y  y     win,pb,str
0x13 32  0  8  8  8  8  0  8  8 1 0x00--         y  y  y     win,pb,str
0x14 32  0  8  8  8  8  0  0  8 1 0x00--         y  y  y     win,pb,str
0x15 24  0  8  8  8  0 24  8  0 0 0x00--         y  y  y     win,pb,str
0x16 24  0  8  8  8  0 24  0  0 0 0x00--         y  y  y     win,pb,str
0x17 24  0  8  8  8  0  0  8  0 0 0x00--         y  y  y     win,pb,str
0x18 24  0  8  8  8  0  0  0  0 0 0x00--         y  y  y     win,pb,str
0x19 24  0  8  8  8  0 24  8  2 1 0x00--         y  y  y     win,pb,str
0x1a 24  0  8  8  8  0 24  0  2 1 0x00--         y  y  y     win,pb,str
0x1b 24  0  8  8  8  0  0  8  2 1 0x00--         y  y  y     win,pb,str
0x1c 24  0  8  8  8  0  0  0  2 1 0x00--         y  y  y     win,pb,str
0x1d 24  0  8  8  8  0 24  8  4 1 0x00--         y  y  y     win,pb,str
0x1e 24  0  8  8  8  0 24  8  4 1 0x00--         y  y  y     win,pb,str
0x1f 24  0  8  8  8  0 24  0  4 1 0x00--         y  y  y     win,pb,str
0x20 24  0  8  8  8  0 24  0  4 1 0x00--         y  y  y     win,pb,str
0x21 24  0  8  8  8  0  0  8  4 1 0x00--         y  y  y     win,pb,str
0x22 24  0  8  8  8  0  0  8  4 1 0x00--         y  y  y     win,pb,str
0x23 24  0  8  8  8  0  0  0  4 1 0x00--         y  y  y     win,pb,str
0x24 24  0  8  8  8  0  0  0  4 1 0x00--         y  y  y     win,pb,str
0x25 24  0  8  8  8  0 24  8  8 1 0x00--         y  y  y     win,pb,str
0x26 24  0  8  8  8  0 24  0  8 1 0x00--         y  y  y     win,pb,str
0x27 24  0  8  8  8  0  0  8  8 1 0x00--         y  y  y     win,pb,str
0x28 24  0  8  8  8  0  0  0  8 1 0x00--         y  y  y     win,pb,str
0x29 16  0  5  6  5  0 24  8  0 0 0x00--         y  y  y     win,pb,str
0x2a 16  0  5  6  5  0 24  0  0 0 0x00--         y  y  y     win,pb,str
0x2b 16  0  5  6  5  0 16  0  0 0 0x00--         y  y  y     win,pb,str
0x2c 16  0  5  6  5  0  0  8  0 0 0x00--         y  y  y     win,pb,str
0x2d 16  0  5  6  5  0  0  0  0 0 0x00--         y  y  y     win,pb,str
0x2e 16  0  5  6  5  0 24  8  2 1 0x00--         y  y  y     win,pb,str
0x2f 16  0  5  6  5  0 24  0  2 1 0x00--         y  y  y     win,pb,str
0x30 16  0  5  6  5  0 16  0  2 1 0x00--         y  y  y     win,pb,str
0x31 16  0  5  6  5  0  0  8  2 1 0x00--         y  y  y     win,pb,str
0x32 16  0  5  6  5  0  0  0  2 1 0x00--         y  y  y     win,pb,str
0x33 16  0  5  6  5  0 24  8  4 1 0x00--         y  y  y     win,pb,str
0x34 16  0  5  6  5  0 24  8  4 1 0x00--         y  y  y     win,pb,str
0x35 16  0  5  6  5  0 24  0  4 1 0x00--         y  y  y     win,pb,str
0x36 16  0  5  6  5  0 24  0  4 1 0x00--         y  y  y     win,pb,str
0x37 16  0  5  6  5  0 16  0  4 1 0x00--         y  y  y     win,pb,str
0x38 16  0  5  6  5  0 16  0  4 1 0x00--         y  y  y     win,pb,str
0x39 16  0  5  6  5  0  0  8  4 1 0x00--         y  y  y     win,pb,str
0x3a 16  0  5  6  5  0  0  8  4 1 0x00--         y  y  y     win,pb,str
0x3b 16  0  5  6  5  0  0  0  4 1 0x00--         y  y  y     win,pb,str
0x3c 16  0  5  6  5  0  0  0  4 1 0x00--         y  y  y     win,pb,str
0x3d 16  0  5  6  5  0 24  8  8 1 0x00--         y  y  y     win,pb,str
0x3e 16  0  5  6  5  0 24  0  8 1 0x00--         y  y  y     win,pb,str
0x3f 16  0  5  6  5  0 16  0  8 1 0x00--         y  y  y     win,pb,str
0x40 16  0  5  6  5  0  0  8  8 1 0x00--         y  y  y     win,pb,str
0x41 16  0  5  6  5  0  0  0  8 1 0x00--         y  y  y     win,pb,str
X11 platform:
    EGL_EXT_output_base EGL_EXT_stream_acquire_mode EGL_EXT_sync_reuse
    EGL_KHR_image_pixmap EGL_KHR_reusable_sync EGL_KHR_stream
    EGL_KHR_stream_attrib EGL_KHR_stream_consumer_gltexture
    EGL_KHR_stream_cross_process_fd EGL_KHR_stream_fifo
    EGL_KHR_stream_producer_eglsurface EGL_KHR_surfaceless_context
    EGL_KHR_wait_sync EGL_NV_nvrm_fence_sync EGL_NV_post_sub_buffer
Configurations:
0x01 32  0  8  8  8  8 24  8  0 0 0x24--         y  y  y     win,pb,pix,str
0x02 32  0  8  8  8  8 24  8  0 0 0x7a--         y  y  y     win,pb,pix,str
0x03 32  0  8  8  8  8 24  8  0 0 0x4f--         y  y  y     win,pb,pix,str
0x04 32  0  8  8  8  8 24  0  0 0 0x28--         y  y  y     win,pb,pix,str
0x05 32  0  8  8  8  8 24  0  0 0 0x7e--         y  y  y     win,pb,pix,str
0x06 32  0  8  8  8  8 24  0  0 0 0x53--         y  y  y     win,pb,pix,str
0x07 32  0  8  8  8  8  0  0  0 0 0x2c--         y  y  y     win,pb,pix,str
0x08 32  0  8  8  8  8  0  0  0 0 0x82--         y  y  y     win,pb,pix,str
0x09 32  0  8  8  8  8  0  0  0 0 0x57--         y  y  y     win,pb,pix,str
0x0a 32  0  8  8  8  8 24  8  2 1 0x38--         y  y  y     win,pb,str
0x0b 32  0  8  8  8  8 24  8  2 1 0x8e--         y  y  y     win,pb,str
0x0c 32  0  8  8  8  8 24  8  2 1 0x63--         y  y  y     win,pb,str
0x0d 32  0  8  8  8  8 24  0  2 1 0x30--         y  y  y     win,pb,str
0x0e 32  0  8  8  8  8 24  0  2 1 0x86--         y  y  y     win,pb,str
0x0f 32  0  8  8  8  8 24  0  2 1 0x5b--         y  y  y     win,pb,str
0x10 32  0  8  8  8  8 24  8  4 1 0x3a--         y  y  y     win,pb,str
0x11 32  0  8  8  8  8 24  8  4 1 0x90--         y  y  y     win,pb,str
0x12 32  0  8  8  8  8 24  8  4 1 0x65--         y  y  y     win,pb,str
0x13 32  0  8  8  8  8 24  0  4 1 0x32--         y  y  y     win,pb,str
0x14 32  0  8  8  8  8 24  0  4 1 0x88--         y  y  y     win,pb,str
0x15 32  0  8  8  8  8 24  0  4 1 0x5d--         y  y  y     win,pb,str
0x16 32  0  8  8  8  8 24  8  8 1 0x44--         y  y  y     win,pb,str
0x17 32  0  8  8  8  8 24  8  8 1 0x9a--         y  y  y     win,pb,str
0x18 32  0  8  8  8  8 24  8  8 1 0x6f--         y  y  y     win,pb,str
0x19 32  0  8  8  8  8 24  0  8 1 0x40--         y  y  y     win,pb,str
0x1a 32  0  8  8  8  8 24  0  8 1 0x96--         y  y  y     win,pb,str
0x1b 32  0  8  8  8  8 24  0  8 1 0x6b--         y  y  y     win,pb,str
0x1c 32  0  8  8  8  8 24  8 16 1 0x4c--         y  y  y     win,pb,str
0x1d 32  0  8  8  8  8 24  8 16 1 0xa2--         y  y  y     win,pb,str
0x1e 32  0  8  8  8  8 24  8 16 1 0x77--         y  y  y     win,pb,str
0x1f 32  0  8  8  8  8 24  0 16 1 0x48--         y  y  y     win,pb,str
0x20 32  0  8  8  8  8 24  0 16 1 0x9e--         y  y  y     win,pb,str
0x21 32  0  8  8  8  8 24  0 16 1 0x73--         y  y  y     win,pb,str
0x22 24  0  8  8  8  0 24  8  0 0 0x21--         y  y  y     win,pb,pix,str
0x23 24  0  8  8  8  0 24  8  0 0 0x23--         y  y  y     win,pb,pix,str
0x24 24  0  8  8  8  0 24  8  0 0 0x22--         y  y  y     win,pb,pix,str
0x25 24  0  8  8  8  0 24  0  0 0 0x27--         y  y  y     win,pb,pix,str
0x26 24  0  8  8  8  0 24  0  0 0 0x7d--         y  y  y     win,pb,pix,str
0x27 24  0  8  8  8  0 24  0  0 0 0x52--         y  y  y     win,pb,pix,str
0x28 24  0  8  8  8  0  0  0  0 0 0x2b--         y  y  y     win,pb,pix,str
0x29 24  0  8  8  8  0  0  0  0 0 0x81--         y  y  y     win,pb,pix,str
0x2a 24  0  8  8  8  0  0  0  0 0 0x56--         y  y  y     win,pb,pix,str
0x2b 24  0  8  8  8  0 24  8  2 1 0x37--         y  y  y     win,pb,str
0x2c 24  0  8  8  8  0 24  8  2 1 0x8d--         y  y  y     win,pb,str
0x2d 24  0  8  8  8  0 24  8  2 1 0x62--         y  y  y     win,pb,str
0x2e 24  0  8  8  8  0 24  0  2 1 0x2f--         y  y  y     win,pb,str
0x2f 24  0  8  8  8  0 24  0  2 1 0x85--         y  y  y     win,pb,str
0x30 24  0  8  8  8  0 24  0  2 1 0x5a--         y  y  y     win,pb,str
0x31 24  0  8  8  8  0 24  8  4 1 0x39--         y  y  y     win,pb,str
0x32 24  0  8  8  8  0 24  8  4 1 0x8f--         y  y  y     win,pb,str
0x33 24  0  8  8  8  0 24  8  4 1 0x64--         y  y  y     win,pb,str
0x34 24  0  8  8  8  0 24  0  4 1 0x31--         y  y  y     win,pb,str
0x35 24  0  8  8  8  0 24  0  4 1 0x87--         y  y  y     win,pb,str
0x36 24  0  8  8  8  0 24  0  4 1 0x5c--         y  y  y     win,pb,str
0x37 24  0  8  8  8  0 24  8  8 1 0x43--         y  y  y     win,pb,str
0x38 24  0  8  8  8  0 24  8  8 1 0x99--         y  y  y     win,pb,str
0x39 24  0  8  8  8  0 24  8  8 1 0x6e--         y  y  y     win,pb,str
0x3a 24  0  8  8  8  0 24  0  8 1 0x3f--         y  y  y     win,pb,str
0x3b 24  0  8  8  8  0 24  0  8 1 0x95--         y  y  y     win,pb,str
0x3c 24  0  8  8  8  0 24  0  8 1 0x6a--         y  y  y     win,pb,str
0x3d 24  0  8  8  8  0 24  8 16 1 0x4b--         y  y  y     win,pb,str
0x3e 24  0  8  8  8  0 24  8 16 1 0xa1--         y  y  y     win,pb,str
0x3f 24  0  8  8  8  0 24  8 16 1 0x76--         y  y  y     win,pb,str
0x40 24  0  8  8  8  0 24  0 16 1 0x47--         y  y  y     win,pb,str
0x41 24  0  8  8  8  0 24  0 16 1 0x9d--         y  y  y     win,pb,str
0x42 24  0  8  8  8  0 24  0 16 1 0x72--         y  y  y     win,pb,str
0x43 16  0  5  6  5  0 24  8  0 0 0x00--         y  y  y     pb,str
0x44 16  0  5  6  5  0 24  0  0 0 0x00--         y  y  y     pb,str
0x45 16  0  5  6  5  0 16  0  0 0 0x00--         y  y  y     pb,str
0x46 16  0  5  6  5  0  0  0  0 0 0x00--         y  y  y     pb,str
Surfaceless platform:
    EGL_EXT_output_base EGL_EXT_protected_content
Configurations:
0x01 32  0  8  8  8  8 24  8  0 0 0x00--         y  y  y     pb,str
0x02 32  0  8  8  8  8 24  0  0 0 0x00--         y  y  y     pb,str
0x03 32  0  8  8  8  8  0  8  0 0 0x00--         y  y  y     pb,str
0x04 32  0  8  8  8  8  0  0  0 0 0x00--         y  y  y     pb,str
0x05 32  0  8  8  8  8 24  8  2 1 0x00--         y  y  y     pb,str
0x06 32  0  8  8  8  8 24  0  2 1 0x00--         y  y  y     pb,str
0x07 32  0  8  8  8  8  0  8  2 1 0x00--         y  y  y     pb,str
0x08 32  0  8  8  8  8  0  0  2 1 0x00--         y  y  y     pb,str
0x09 32  0  8  8  8  8 24  8  4 1 0x00--         y  y  y     pb,str
0x0a 32  0  8  8  8  8 24  8  4 1 0x00--         y  y  y     pb,str
0x0b 32  0  8  8  8  8 24  0  4 1 0x00--         y  y  y     pb,str
0x0c 32  0  8  8  8  8 24  0  4 1 0x00--         y  y  y     pb,str
0x0d 32  0  8  8  8  8  0  8  4 1 0x00--         y  y  y     pb,str
0x0e 32  0  8  8  8  8  0  8  4 1 0x00--         y  y  y     pb,str
0x0f 32  0  8  8  8  8  0  0  4 1 0x00--         y  y  y     pb,str
0x10 32  0  8  8  8  8  0  0  4 1 0x00--         y  y  y     pb,str
0x11 32  0  8  8  8  8 24  8  8 1 0x00--         y  y  y     pb,str
0x12 32  0  8  8  8  8 24  0  8 1 0x00--         y  y  y     pb,str
0x13 32  0  8  8  8  8  0  8  8 1 0x00--         y  y  y     pb,str
0x14 32  0  8  8  8  8  0  0  8 1 0x00--         y  y  y     pb,str
0x15 24  0  8  8  8  0 24  8  0 0 0x00--         y  y  y     pb,str
0x16 24  0  8  8  8  0 24  0  0 0 0x00--         y  y  y     pb,str
0x17 24  0  8  8  8  0  0  8  0 0 0x00--         y  y  y     pb,str
0x18 24  0  8  8  8  0  0  0  0 0 0x00--         y  y  y     pb,str
0x19 24  0  8  8  8  0 24  8  2 1 0x00--         y  y  y     pb,str
0x1a 24  0  8  8  8  0 24  0  2 1 0x00--         y  y  y     pb,str
0x1b 24  0  8  8  8  0  0  8  2 1 0x00--         y  y  y     pb,str
0x1c 24  0  8  8  8  0  0  0  2 1 0x00--         y  y  y     pb,str
0x1d 24  0  8  8  8  0 24  8  4 1 0x00--         y  y  y     pb,str
0x1e 24  0  8  8  8  0 24  8  4 1 0x00--         y  y  y     pb,str
0x1f 24  0  8  8  8  0 24  0  4 1 0x00--         y  y  y     pb,str
0x20 24  0  8  8  8  0 24  0  4 1 0x00--         y  y  y     pb,str
0x21 24  0  8  8  8  0  0  8  4 1 0x00--         y  y  y     pb,str
0x22 24  0  8  8  8  0  0  8  4 1 0x00--         y  y  y     pb,str
0x23 24  0  8  8  8  0  0  0  4 1 0x00--         y  y  y     pb,str
0x24 24  0  8  8  8  0  0  0  4 1 0x00--         y  y  y     pb,str
0x25 24  0  8  8  8  0 24  8  8 1 0x00--         y  y  y     pb,str
0x26 24  0  8  8  8  0 24  0  8 1 0x00--         y  y  y     pb,str
0x27 24  0  8  8  8  0  0  8  8 1 0x00--         y  y  y     pb,str
0x28 24  0  8  8  8  0  0  0  8 1 0x00--         y  y  y     pb,str
0x29 16  0  5  6  5  0 24  8  0 0 0x00--         y  y  y     pb,str
0x2a 16  0  5  6  5  0 24  0  0 0 0x00--         y  y  y     pb,str
0x2b 16  0  5  6  5  0 16  0  0 0 0x00--         y  y  y     pb,str
0x2c 16  0  5  6  5  0  0  8  0 0 0x00--         y  y  y     pb,str
0x2d 16  0  5  6  5  0  0  0  0 0 0x00--         y  y  y     pb,str
0x2e 16  0  5  6  5  0 24  8  2 1 0x00--         y  y  y     pb,str
0x2f 16  0  5  6  5  0 24  0  2 1 0x00--         y  y  y     pb,str
0x30 16  0  5  6  5  0 16  0  2 1 0x00--         y  y  y     pb,str
0x31 16  0  5  6  5  0  0  8  2 1 0x00--         y  y  y     pb,str
0x32 16  0  5  6  5  0  0  0  2 1 0x00--         y  y  y     pb,str
0x33 16  0  5  6  5  0 24  8  4 1 0x00--         y  y  y     pb,str
0x34 16  0  5  6  5  0 24  8  4 1 0x00--         y  y  y     pb,str
0x35 16  0  5  6  5  0 24  0  4 1 0x00--         y  y  y     pb,str
0x36 16  0  5  6  5  0 24  0  4 1 0x00--         y  y  y     pb,str
0x37 16  0  5  6  5  0 16  0  4 1 0x00--         y  y  y     pb,str
0x38 16  0  5  6  5  0 16  0  4 1 0x00--         y  y  y     pb,str
0x39 16  0  5  6  5  0  0  8  4 1 0x00--         y  y  y     pb,str
0x3a 16  0  5  6  5  0  0  8  4 1 0x00--         y  y  y     pb,str
0x3b 16  0  5  6  5  0  0  0  4 1 0x00--         y  y  y     pb,str
0x3c 16  0  5  6  5  0  0  0  4 1 0x00--         y  y  y     pb,str
0x3d 16  0  5  6  5  0 24  8  8 1 0x00--         y  y  y     pb,str
0x3e 16  0  5  6  5  0 24  0  8 1 0x00--         y  y  y     pb,str
0x3f 16  0  5  6  5  0 16  0  8 1 0x00--         y  y  y     pb,str
0x40 16  0  5  6  5  0  0  8  8 1 0x00--         y  y  y     pb,str
0x41 16  0  5  6  5  0  0  0  8 1 0x00--         y  y  y     pb,str
Device platform:
Device #0:
EGL device extensions string:
    EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node
    EGL_EXT_device_query_name EGL_EXT_device_persistent_id
Platform Device:
Configurations:
Device #1:
    EGL_EXT_device_drm
Platform Device:
libEGL warning: DRI2: failed to create dri screen
Device #2:
    EGL_MESA_device_software
Platform Device:
EGL vendor string: Mesa Project
EGL client APIs: OpenGL OpenGL_ES
EGL driver name: swrast
    EGL_EXT_create_context_robustness EGL_KHR_cl_event2
    EGL_KHR_config_attribs EGL_KHR_context_flush_control
    EGL_KHR_create_context EGL_KHR_create_context_no_error
    EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses
    EGL_KHR_gl_texture_cubemap_image EGL_KHR_image_base
    EGL_KHR_no_config_context EGL_KHR_reusable_sync
    EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float
    EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image
    EGL_MESA_query_driver
Configurations:
0x01 32  0 10 10 10  2  0  0  0 0 0x00--      a  y  y  y     pb
0x02 32  0 10 10 10  2 16  0  0 0 0x00--      a  y  y  y     pb
0x03 32  0 10 10 10  2 24  0  0 0 0x00--      a  y  y  y     pb
0x04 32  0 10 10 10  2 24  8  0 0 0x00--      a  y  y  y     pb
0x05 32  0 10 10 10  2 32  0  0 0 0x00--      a  y  y  y     pb
0x06 30  0 10 10 10  0  0  0  0 0 0x00--      y  y  y  y     pb
0x07 30  0 10 10 10  0 16  0  0 0 0x00--      y  y  y  y     pb
0x08 30  0 10 10 10  0 24  0  0 0 0x00--      y  y  y  y     pb
0x09 30  0 10 10 10  0 24  8  0 0 0x00--      y  y  y  y     pb
0x0a 30  0 10 10 10  0 32  0  0 0 0x00--      y  y  y  y     pb
0x0b 32  0  8  8  8  8  0  0  0 0 0x00--      a  y  y  y     pb
0x0c 32  0  8  8  8  8 16  0  0 0 0x00--      a  y  y  y     pb
0x0d 32  0  8  8  8  8 24  0  0 0 0x00--      a  y  y  y     pb
0x0e 32  0  8  8  8  8 24  8  0 0 0x00--      a  y  y  y     pb
0x0f 32  0  8  8  8  8 32  0  0 0 0x00--      a  y  y  y     pb
0x10 24  0  8  8  8  0  0  0  0 0 0x00--      y  y  y  y     pb
0x11 24  0  8  8  8  0 16  0  0 0 0x00--      y  y  y  y     pb
0x12 24  0  8  8  8  0 24  0  0 0 0x00--      y  y  y  y     pb
0x13 24  0  8  8  8  0 24  8  0 0 0x00--      y  y  y  y     pb
0x14 24  0  8  8  8  0 32  0  0 0 0x00--      y  y  y  y     pb
0x15 16  0  5  6  5  0  0  0  0 0 0x00--      y  y  y  y     pb
0x16 16  0  5  6  5  0 16  0  0 0 0x00--      y  y  y  y     pb
0x17 16  0  5  6  5  0 24  0  0 0 0x00--      y  y  y  y     pb
0x18 16  0  5  6  5  0 24  8  0 0 0x00--      y  y  y  y     pb
0x19 16  0  5  6  5  0 32  0  0 0 0x00--      y  y  y  y     pb
Adding these to Section “Screen” in xorg.conf seems to have fixed my crashing issue:
Option         "ForceCompositionPipeline" "true"
Option         "ForceFullCompositionPipeline" "true"
The game is running so much smoother, barely any “stutter” which would happen here and there. So:
  1. I Don’t need to do any form of modprobe nvidia-drm modeset=1, whether manually or via modprobe.d
  2. I Don’t add any special section in xorg.conf for Option “IgnoreABI” “1”
  3. I Added the two CompositionPipeline lines above to Section “Screen” in my xorg.conf
Before the game would have periods or bursts of very low framerates with loading activity, which could lead to a freeze up. Now that doesn’t really happen as much or at all and it behaves more like when I play under Windows 10 on the same box.
What led me here:
Desktop has least amount of tearing(really none) I’ve seen when moving windows really fast.
Fingers crossed! If it holds up I will mark this as the solution in a couple of days.
Well it crashed, but it seems to behaving much better. I’m going to give up for now, but I’ll probably go through this again when THPS3+4 is released in July. According to protondb.com(love this!), this crashes for a lot of people, so not too hot and bothered by it.
And I should be careful with words, it doesn’t crash, but the display freezes, but I can ssh in fine.
Also, I do need to do the modprobe nvidia_drm modeset=1, or libglvnd won’t be able to use nvidia for gbm. Maybe other things too.
