Is there a way to execute a function or print something to the terminal once a thread has completed?
Sure, just wrap your kernel inside another function.
__global__ mykernel(...)
myRealKernel(...);
MyCleanupFuntionToCallForAllThreadsAsTheyExit(...);
But if I were to run that I still could not have a print function in the MyCleanupFuntionToCallForAllThreadsAsTheyExit function because it would need to be a device function. Is there anyway to have a functino be called that is not a device function after each thread is complete?
If you want a print function, you could try using the GPU Trace library
