thread-local variables
I have a kernel subroutine like this:
attributes(global) subroutine FrontSweep_cuda
 integer,value :: d, s, w, n_ways
 integer,value :: i,j
 integer,value ::  fmi, fmj, fmk, fm_id
 real,value :: in_bound(3), out_bound(3), lax3_factor(3)
 real, value ::  bot, top, avg, IsZero
 do s=3, ncap_gpu
 n_ways=ini_stage(s+1)-ini_stage(s)
 do w=blockidx%x, n_ways, griddim%x
 do d=threadidx%x, num_dir_gpu, blockdim%x
     if(o_pnt_gpu(1) .lt. 0) then
        fmi=cap_gpu(1)- x_draw( ini_stage(s)+w-1 )+1
     else
        fmi=x_draw( ini_stage(s)+w-1 )
     endif
     if(o_pnt_gpu(2) .lt. 0) then
        fmj=cap_gpu(2)- y_draw( ini_stage(s)+w-1 )+1
     else
        fmj=y_draw( ini_stage(s)+w-1 )
     endif
     if(o_pnt_gpu(3) .lt. 0) then
        fmk=cap_gpu(3)- z_draw( ini_stage(s)+w-1 )+1
     else
        fmk=z_draw( ini_stage(s)+w-1 )
     endif
     in_bound(1)=iflux(fmj,fmk,d)
     in_bound(2)=jflux(fmi,fmk,d)
     in_bound(3)=kflux(fmi,fmj,d)
     fm_id=m_matrix_gpu(fmi,fmj,fmk)
     IsZero=0
     lax3_factor=1
     bot=sigt_gpu(fm_id)
     top=asrcflx_gpu(fmi,fmj,fmk,d)
     do i=1,3
       bot=bot+2*cos_dager_gpu(i,d)
       top=top+2*cos_dager_gpu(i,d)*in_bound(i)
     enddo
  do while (IsZero .eq. 0)
    avg=top/bot
    IsZero=1
    do i=1,3
      if(lax3_factor(i) .eq. 0) cycle
      out=2*avg-in_bound(i)
      if (out .lt. 0)  then
        out_bound(i)=0.0
        lax3_factor(i)=0
        top=top-cos_dager_gpu(i,d)*in_bound(i)
        bot=bot-2*cos_dager_gpu(i,d)
        IsZero =0
        exit
      else
        out_bound(i)=out
      endif
   enddo
  enddo !do while
  iflux(fmj,fmk,d)=out_bound(1)
  jflux(fmi,fmk,d)=out_bound(2)
  kflux(fmi,fmj,d)=out_bound(3)
  asrcflx_gpu(fmi,fmj,fmk,d)=avg
 enddo !dir
 enddo !ways
 call syncthreads()
 enddo !stage
 return
end subroutine
all the variables I defined in the beginning are intended to be local to a thread, which means each thread will see different values of these variables.
I wonder if the complier can recognize them as thread-local, including in_bound(3), out_bound(3), and lax3_factor(3) ?
Hi tty103,
All local variables are local to each thread so these three variables do not share storage across multiple threads. For shared storage within a block of threads, you would need to explicitly declare the variables with the ‘shared’ attribute.
  • Mat
thanks. another question, sorry if this is asked before
module mCuda
real, allocatable, device :: MyArray(:,:,:)
attribute(global) subroutine test_cuda
integer i,j,k
do i=threadidx%x , 100, blockdim%x
do j=threadidx%y , 100, blockdim%y
do k=threadidx%z,  100, blockdim%z
  MyArray(i,j,k)=1
enddo
enddo
enddo
end subroutine
end module
i, j, k are local to thread, I wonder how the complier knows MyArray is not, which means I only need to allocate one copy of MyArray, not one for every thread.
if I pull the i, j, k out of the subroutine
module mCuda
integer i, j, k
  MyArray(i,j,k)=1
enddo
enddo
enddo
end subroutine
end module
does the compile still know i,j,k are local?
Because MyArray has module scope hence is visible to all routines within the module.
But they aren’t local any longer. By moving them to the module data section, they are given module scope and hence accessible by all threads.
Also, they are host variables (no device attribute) so you’ll have problems access them on the device.
  • Mat
