Hi
I have a couple of basic questions regarding gdb. I have launched a program with 1024 threads. According to info cuda sms
, only SM 0 is active.
* 0 0x00000000ffffffff
67 0x0000000000000000
1- Is there a way to manually dispatch the threads? I mean SM0 and SM1 each having 512 threads.
2- What does the meaning of the mask value? That 0xFFFFFFFF is 64 1-digit.
Another thing is about the limit on the number of threads. When I launch 1024 threads, the active warps are shown like this:
(cuda-gdb) info cuda warps
Wp Active Lanes Mask Divergent Lanes Mask Active Physical PC Kernel BlockIdx First Active ThreadIdx
Device 0 SM 0
* 0 0xffffffff 0x00000000 0x00000000000000f0 0 (0,0,0) (0,0,0)
1 0xffffffff 0x00000000 0x00000000000000f0 0 (0,0,0) (32,0,0)
2 0xffffffff 0x00000000 0x00000000000000f0 0 (0,0,0) (64,0,0)
30 0xffffffff 0x00000000 0x00000000000000f0 0 (0,0,0) (960,0,0)
31 0xffffffff 0x00000000 0x00000000000000f0 0 (0,0,0) (992,0,0)
32 0x00000000 0x00000000 n/a n/a n/a n/a
33 0x00000000 0x00000000 n/a n/a n/a n/a
46 0x00000000 0x00000000 n/a n/a n/a n/a
47 0x00000000 0x00000000 n/a n/a n/a n/a
That is normal, but this output is saying that there are 16 idle warps available on SM 0. But if I increase the number of threads from 1024 to 1025, warp 32 is not activated and the program returns an error.
3- Is there any way to activate warps 32-47?
Hi @mahmood.nt,
Thank you for your questions! I will address some of them and re-direct your post to a different forum branch for detailed answers for the rest.
This is more a CUDA programming question (for CUDA Programming and Performance - NVIDIA Developer Forums branch), but I think it’s not possible (unless you tweak your kernel in a way, that only 512 threads would fit into singe SM).
This mask values shows that 32 warps (note that 0xFFFFFFFF
has 32 bits set to 1) are active on SM 0.
Again, folks on CUDA Programming and Performance - NVIDIA Developer Forums can provide more detailed answer, but this can be related to SM-level resource constrains (e.g. there might not be sufficient number of registers available to run 33 warps at the same time).
I have also moved this topic to CUDA Programming and Performance - NVIDIA Developer Forums
No, you cannot manually dispatch threads.
1025 threads per block is illegal in CUDA.
If you want to see additional warps active on a particular SM, its necessary to get multiple blocks resident on that SM. As already indicated, these things depend on your actual source code and cannot be “forced”. It’s a question of occupancy and launch configuration. Since there are 16 idle warps on the SM (32 occupied) it suggests your GPU has a limit of 1536 threads per SM. So you would want to launch threadblocks of 512 threads each, and have enough to fully fill every SM (at least 3 times the numbers of SMs on your GPU). Then (assuming occupancy calculation permits) you should see 48 active warps per SM.
Thanks for the explanations. With 68 SMs and a block of 512 threads, a launch of <<<68, 512>>> fills all SMs and in each SM, 1/3 of warps (16/48) are resident.
I then continued with <<<204, 512>>> where 204/68=3 So all SMs and warps become full and I can verify that with info cuda sms
and info cuda warps
When I launch <<<205, 512>>>, everything is the same as before, however, one block of 512 threads must be inactive. But I couldn’t find a command to see in-queue threads on an SM. Is there any way to see those threads waiting for resources? Or maybe inactive threads are not yet assigned to a SM. What do you think about that?
Correct. Initially, at least, the 205th block wouldn’t be assigned to an SM, until resources on a SM become available. Regarding what you can inspect in cuda-gdb, that is a question for the cuda-gdb forum.
