Hi!
I am using a threadripper 1950X to run my simulation code. It is compiled with pgf90 with optimization turned on.
Execution times appear to be on the order of 5 to 10% longer on the 1950X compared to an i7-4770 with the same pgi fortran installed with the same compiler options (basically just -O).
pgf90 -V gives the following output
pgf90 17.10-0 64-bit target on x86-64 Linux -tp piledriver
PGI Compilers and Tools
Copyright (c) 2017, NVIDIA CORPORATION. All rights reserved.
… which identifies the system as piledriver which is not accurate but may still be the best choice (?) for the current pgi compilers?
Since Ryzen CPUs have been out almost a year now … I was wondering if there is a better choice for the -tp option for using pgi fortran for compiling on AMD targets. I was also wondering if there are other options that would give better single thread performance.
Based on available benchmarking data the 1950X should be slightly ahead of the i7-4770 for single thread performance.
