I am executing deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt via remote ssh tool
You can see the picture on the monitor external to the AGX
However, when I remotely execute the python demo through the SSH tool, I can only execute it through the external screen, otherwise the screen will not be displayed. How to deal with it?
You can execute “export DISPLAY=:0” before executing deepstream-app command, in this way the deepstream-app will use the default external monitor although you execute the command on SSH remotely.
Also I have a problem with gstreamer.
I use the following code to store the video in segments, but I found that if the program terminates unexpectedly or manually uses Ctrl+C to terminate, the last video of the segment cannot be played. I saw that the official website gives the attribute moov-recovery-file To solve it, but I can’t achieve it, how can I do it?
