Thrust and the Driver API Is it possible?
I’ve been working with the Driver API, and wanted to use some Thrust functions to save some time. However, I’ve been running into a few problems. For some background, I want to have a C++ file as my program entry point, and have it call a wrapper-like function that first does some setup with Thrust, then calls a kernel.
The problem is that the Thrust code needs to be compiled by nvcc, so I’ve been putting my wrapper-function in my .cu file(s). However, Thrust is meant to execute on the host, not the device, so I can’t invoke the wrapper function as I might a normal kernel (via cuLaunchKernel). Using the Runtime API, this isn’t a problem; I can just declare the host-based function as being extern, and call it from my C++ file. However, whenever I try using the Driver API, I can never link to anything in any of the .cu files (as an aside, is this because they’re generating a ptx file?).
I wrote a small example to illustrate the crux of what I want to do; although it doesn’t involve Thrust, it illustrates my linking problem.
This is in my .cu file, (named thekernel.cu):
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <builtin_types.h>
#include <cutil_inline.h>
__global__ void cudaKernel(float *img, unsigned const int width, unsigned const int height){
	int x = blockIdx.x *  blockDim.x + threadIdx.x;
	int y = blockIdx.y *  blockDim.y + threadIdx.y;
	if(x >= width)
		return;
	if(y >= height)
		return;
	if(img[y * width + x] == 0)
		img[y * width + x] = 1;
	else
		img[y * width + x] = 0;
void initCUDA(CUfunction *theKernel){
	CUcontext context;
	CUdevice cuDevice = 0;
	CUmodule cuMod;
	CUresult result = cuInit(0);
	cuDeviceGet(&cuDevice, 0);
	cuCtxCreate(&context, 0, cuDevice);
	cuModuleLoad(&cuMod, "./thekernel.ptx");
	cuModuleGetFunction(theKernel, cuMod, "cudaKernel");
int iDivUp(int a, int b){
	return (a % b != 0) ? (a / b + 1) : (a / b);
extern "C" void cudaKernelWrapper(float *img, unsigned const int height, unsigned const int width){
	CUfunction theKernel;
	initCUDA(&theKernel);
	dim3 threads(16,16,1);
	dim3 blocks(iDivUp(width, threads.x), iDivUp(height, threads.y), 1);
	float* devData;
    cuMemAlloc((CUdeviceptr *) &devData, height*width*sizeof(float));
	cuMemcpyHtoD((CUdeviceptr)devData, img, height*width*sizeof(float));
	void *kernelArgs[] = {&devData, (void *)&width, (void *)&height};
	cuLaunchKernel(theKernel, blocks.x, blocks.y, blocks.z, threads.x, threads.y, threads.z, 0, 0, kernelArgs, NULL);
	cuCtxSynchronize();
	cuMemcpyDtoH(img, (CUdeviceptr)devData, height*width*sizeof(float));
	cuMemFree((CUdeviceptr)devData);
Then in my C++ file:
#include <stdio.h>
#include <stdlib.h>
//openCV includes
#include <cv.h>
#include <highgui.h>
extern "C" void cudaKernelWrapper(float *, unsigned const int, unsigned const int);
int main(){
	unsigned const int height = 256;
	unsigned const int width = 512;
	float *fakeImg = (float *)malloc(height * width * sizeof(float));
	cv::Mat outImg;
	outImg = cv::Mat(height, width, CV_32FC1);
	for (unsigned int i = 0; i < height; i++){
		for (unsigned int j = 0; j < width-height; j++){
			fakeImg[i*width+j] = 1;
		for (unsigned int k = height; k < width; k++){
			fakeImg[i*width+k] = 0;
	outImg.data = (unsigned char *)fakeImg;
	imshow("PreImage", outImg);
	cv::waitKey(10);
	cudaKernelWrapper(fakeImg, height, width);
	imshow("PostImage", outImg);
	cv::waitKey(0);
	free(fakeImg);
	return 1;
This always yields a “error LNK2019: unresolved external symbol _cudaKernelWrapper referenced in function _main” linkage error.
If anyone has any insights, they’d be much appreciated
Thanks,
-Al
EDIT:
Not sure if it matters, but I’m using CUDA 4.0 and a GTX 580 (compute capability 2.0)
If anyone has input on this, I’d still be interested in knowing if it’s possible.
