I wrote a code to remove repeated ids from a nested std::vector with thrust::remove_if and thrust::binary_search scaning for repeted ids one outer vector each time. I want to remove only the ids that are most unique in the global scale . The code with thrust::find works correctly coping only the unique ids weareas for the code with thrust::binary_search I does not copy anything. I checked the input vector, and also sorted the id
s before using binary search
Thank in advance
Rafael Scatena
functors:
struct nonRepeatedTriangle {
int64_t* idSetBegin; int64_t* idSetEnd;
__host__ __device__
nonRepeatedTriangle(int64_t* begin, int64_t* end) : idSetBegin(begin), idSetEnd(end) {}
__host__ __device__
bool operator()(const int64_t& t) const {
bool result = thrust::binary_search(thrust::device, idSetBegin, idSetEnd, t);
printf("Checking %lld: Result = %d\n", t, result);
return !result;}};
struct nonRepeatedTriangle_find {
int64_t* id_start; int64_t* id_end;
__host__ __device__
nonRepeatedTriangle_find(int64_t* start, int64_t* end) : id_start(start), id_end(end) {}
__host__ __device__
bool operator()(const int64_t& t) const {return thrust::find(thrust::device, id_start, id_end, t) != id_end;}};
function:
__host__ void delete_repeated_triangles(std::vector<std::vector<int64_t>>& TriangleL,std::vector<OctreeNode>& vector_nodes,int MAX_LEVEL){
std::unordered_set<int64_t> unique_ids;
for (const auto& row : TriangleL) {for (int64_t id : row) {unique_ids.insert(id);}}
// std::set<int64_t> new_ids(unique_ids.size());
int unique_count = unique_ids.size();
std::vector<int64_t> hi;
hi.push_back((int)unique_ids.size()+1);
hi.push_back((int)unique_ids.size()+2);
thrust::device_vector<int64_t> d_id(2);
thrust::copy(hi.begin(), hi.end(), d_id.begin());
thrust::device_vector<int64_t> new_id;
thrust::sort(thrust::device, d_id.begin(), d_id.end());
// std::cout << "unique : "<< unique_count << std::endl;
int counter =0;
// #pragma omp parallel for
for (int i =0; i< TriangleL.size(); i++){
if((vector_nodes[i].Level==MAX_LEVEL)&&(TriangleL[i].size()>0)){
// thrust::host_vector<int64_t> h_vector(TriangleL[i].size());
// thrust::copy(TriangleL[i].begin(), TriangleL[i].end(), h_vector.begin());
thrust::device_vector<int64_t> d_vector(TriangleL[i].size());
// thrust::device_vector<int64_t> d_output(TriangleL[i].size());
thrust::copy(TriangleL[i].begin(), TriangleL[i].end(), d_vector.begin());
thrust::sort(thrust::device,d_vector.begin(), d_vector.end());
int64_t* id_start = thrust::raw_pointer_cast(d_id.data());
int64_t* id_end = thrust::raw_pointer_cast(d_id.data() + d_id.size());
if(counter==0){d_id = d_vector;}
else{
auto new_end_d_vector = thrust::remove_if(thrust::device, d_vector.begin(), d_vector.end(),
nonRepeatedTriangle(id_start, id_end));
d_vector.resize(new_end_d_vector - d_vector.begin());}
std::cout << "d_vector size: "<< d_vector.size() << std::endl;
new_id.clear(); new_id.shrink_to_fit(); new_id.resize(d_vector.size());
auto end = thrust::copy(thrust::device, d_vector.begin(), d_vector.end(), new_id.begin());
new_id.resize(end - new_id.begin());
d_id.insert(d_id.end(), new_id.begin(), new_id.end());
d_id.erase(thrust::unique(thrust::device, d_id.begin(), d_id.end()), d_id.end());
// std::cout<< "d_id: " << std::endl;for (size_t j = 0; j < std::min(d_id.size(), size_t(1000000000)); j++) {std::cout<< d_id[j] << " ";}
std::cout << "new id size: "<< new_id.size() <<" id size: "<< d_id.size() << std::endl;
TriangleL[i].assign(d_vector.begin(), d_vector.end()); counter++;
binary search output (all negatives):
d_vector size: 5826 d_output size: 0
t: 23804, result: 0 result 2: 0
t: 23807, result: 0 result 2: 0
t: 24130, result: 0 result 2: 0
t: 24131, result: 0 result 2: 0
new id size: 0 id size: 109
t: 18180, result: 0 result 2: 0
t: 18185, result: 0 result 2: 0
t: 18186, result: 0 result 2: 0
t: 18216, result: 0 result 2: 0
find output (some positives):
Checking 2441838: Result = 1
Checking 2441875: Result = 1
Checking 2441902: Result = 1
Checking 2441928: Result = 1
Checking 2441959: Result = 1
Checking 2450944: Result = 1
Checking 2450971: Result = 1
Checking 2451006: Result = 1
Checking 2451037: Result = 1
