Thrust::copy crashes on RTX 2060 with CUDA 11.2
When I use thrust::copy with the following code it crashes
typedef struct Point_2D
	float x_;
	float y_;
	__host__ __device__ Point_2D() : x_(0.0f), y_(0.0f) {}
}Point2D;
thrust::device_vector<Point2D> d_Vector(max_size);  // max_size = 2554
thrust::host_vector<Point2D> h_Vector(max_size);   // max_size = 2554
// Kernel calls which does some operations on d_Vector
auto last_error = cudaPeekAtLastError();
if (last_error != cudaSuccess) {
   return false;
thrust::copy(d_Vector.begin(), d_Vector.end(), h_Vector.begin());  // crashes
I recently upgraded my CUDA library to 11.2. Before I was using 9.2.
This particular code runs on a laptop equipped with GTX 1070, RTX 3070 without any error but fails to run on RTX 2060.
But before with CUDA 9.2, I didn’t have any problem running on RTX 2060.
I am using VS 2017 to build my code. And in Properties > CUDA C/C++ > Device > Code Generation, I have the following compute capability set.
compute_52,sm_52;
compute_61,sm_61;
compute_70,sm_70;
compute_75,sm_75;
compute_80,sm_80;
compute_86,sm_86;
Can anybody please help me out in resolving this issue?
Please let me know if I can provide you with any more information.
I’ll repeat what I said when you asked this on the thrust mailing list:
thrust::copy may be having trouble due to errors in your kernel calls.
Add a:
cudaDeviceSynchronize();
statement before:
With adding cudaDeviceSynchronize() I can know what is the error in Kernel. Now it does not crash. I have to debug the CUDA kernel.
Thanks for your help.
