thrust::copy failed in Xavier, but success in GTX1080
Hi! code as below.
int i = 0;
    size_t n = 100;
    std::vector<float> h_data(n);
    for(i = 0; i < n; ++i) h_data[i] = i;
    thrust::device_vector<float> d_data;
    d_data.resize(h_data.size());
    thrust::copy(thrust::device_pointer_cast(&h_data[0]),
        thrust::device_pointer_cast(&h_data[0]) + h_data.size(),
        d_data.begin());
    std::cout << "start: " << thrust::device_pointer_cast(&h_data[0])
        << std::endl;
    std::cout << "end: " << h_data.size() << std::endl;
        << std::endl;
        std::cout << i << " is " << d_data[i] << std::endl;
It works in GTX1080, but failed in Xavier, error info as below.
Please someone HELP! Thanks a lot!
start: 0x556ad7f6e0
end: 100
end: 0x556ad7f870
terminate called after throwing an instance of 'thrust::system::system_error'
  what():  trivial_device_copy D->H failed: unspecified launch failure
Aborted (core dumped)
This is a known issue that the thrust included in the CUDA toolkit of JetPack4.2 is incorrect.
It can be worked around by downloading open-source Thrust and replacing what is inside CUDA installed on JetPack.
Please check this topic for more information:
[url]https://devtalk.nvidia.com/default/topic/1049859/run-xgboost-with-gpu-error-/[/url]
