Hi, I am building a simple application that uses thrust and OpenMP for host setup and for some reason I am getting the following errors when I try build with CUDA 9 or above:
/usr/local/cuda-9.2/include/thrust/system/omp/detail/sort.inl(120): error: name followed by "::" must be a class or namespace name
/usr/local/cuda-9.2/include/thrust/system/omp/detail/sort.inl(126): error: identifier "decomp" is undefined
/usr/local/cuda-9.2/include/thrust/system/omp/detail/sort.inl(198): error: name followed by "::" must be a class or namespace name
/usr/local/cuda-9.2/include/thrust/system/omp/detail/sort.inl(204): error: identifier "decomp" is undefined
When I build with CUDA 8.0, however, I don’t get the errors. I also tried compiling a very basic program that just includes device_vector.hpp (though using other thrust headers also fails). Here is the code for it:
#include <thrust/version.h>
#include <thrust/device_vector.h>
int main () {}
I am compiling with the following bash script (where the cuda version is set by CUDA_ROOT):
#!/bin/bash -x
CUDA_ROOT=/usr/local/cuda-8.0
CPP=$CUDA_ROOT/bin/nvcc
LDLIBS='-lm -lcudart -lgomp'
THRUST=$CUDA_ROOT/include
LDFLAGS="-L$CUDA_ROOT/lib64 -L$CUDA_ROOT/lib"
CUDA_FLAGS_COMMON='-gencode arch=compute_35,code=sm_35'
$CPP --compiler-options "-Wfatal-errors" $CUDA_FLAGS_COMMON -I$THRUST -I$CUDA_ROOT/include -Xcompiler -fopenmp -DTHRUST_HOST_SYSTEM=THRUST_HOST_SYSTEM_OMP -DTHRUST_DEVICE_SYSTEM=THRUST_DEVICE_SYSTEM_CUDA $LDLIBS $LDFLAGS -o test test.cu
If I take out the -fopenmp and the THRUST_HOST_SYSTEM_OMP I don’t get the compile errors, but I then can’t build the application I’m trying to build since it uses the function
omp_set_num_threads
I have tried this on Windows with VS and Linux with gcc and both seem to be failing for CUDA 9 or above.
