I have two questions regarding Thrust.
Why is there no sub group for Thrust?? :)
If I want to sort a “float *” array inplace using thrust::sort, how do I do this?
Currently I do something like this:
thrust::host_vector<float> h_vec1(50);
float *fData = new float[ 50 ];
thrust::device_vector<float> d_x( &(fData[0]), &(fData[0]) + 50);
thrust::sort(d_x.begin(), d_x.end());
thrust::copy(d_x.begin(), d_x.end(), h_vec.begin());
thrust::copy(h_vec1.begin(), h_vec1.end(), std::ostream_iterator<float>(std::cout, "\n"));
This code uses a temporary host_vector (h_vec1). How do I remove the need for it and copy the sorted
result right back from the device to the original fData array?
thanks
eyal
eelsen
January 20, 2011, 6:42pm
2
thanks
eyal
does
thrust::copy(d_x.begin(), d_x.end(), fData);
not work?
Also regarding 1), the thrust “forum” is here: http://groups.google.com/group/thrust-users
nbell
January 21, 2011, 11:11pm
3
thanks
eyal
There’s no subforum for Thrust, but there is a dedicated mailing list (thrust-users) .
To eliminate the h_vec1 temporary, just use fData directly. Note that fData is a valid “iterator” (just like .begin() and .end()) so you can use fData and fData + 50 to define the beginning and end of the host array. Thrust will assume that a “raw pointer” like fData lives on the host.
thrust::device_vector<float> d_x(fData, fData + 50);
thrust::copy(fData, fData + 50, std::ostream_iterator<float>(std::cout, "\n"));
Very elegant :) works like a charm…
eyal
