Thrust::transform with conditional
This is what my vector subtraction looks like now -
thrust::transform(d_arr2.begin(), d_arr2.end(), d_arr.begin(), data.begin(), thrust::minus<T>());
For each d_arr[i] and d_arr2[i], I want to check
if d_arr2[i] <= d_arr[i]
    Callfunction();
    Don't transform;
(Don’t transform is not super important)
How do I do this without increasing the complexity?
The first thing that came to mind is using thrust::transform_if but I am not sure how to fit a conditional with the function call into it. I would really appreciate any help!
Checkout the transformation section https://github.com/thrust/thrust/wiki/Quick-Start-Guide
Here is a simple solution. I bet there are others as well.
#include <thrust/transform.h>
#include <thrust/device_vector.h>
#include <thrust/host_vector.h>
#include <vector>
__host__ __device__
void Callfunction(int & out, const int & a, const int & b ) {
    out = a * b;
struct functor
  const int scalar;
  functor( int _scalar ) : scalar( _scalar ) {}
  __host__ __device__
  int operator()( const int& x, const int& y ) const
    int temp { INT_MAX };
    if (y < x) {
        std::printf( "Call function\n" );
        Callfunction( temp, y, scalar );
    } else {
        std::printf( "Don't transform\n" );
    return ( temp );
int main (void) {
    std::vector<int> h_arr  = { 3,  6,  2,  1,  2,  3};
    std::vector<int> h_arr2 = {-5,  0, -2,  3,  2, -4};
    thrust::device_vector<int> d_arr ( h_arr );
    thrust::device_vector<int> d_arr2 ( h_arr2 );
    thrust::device_vector<int> d_output ( h_arr.size() );
    const int scalar { 4 };
    thrust::transform( d_arr.begin(), d_arr.end(), d_arr2.begin(), d_output.begin(), functor( scalar ) );
    thrust::host_vector<int> h_output ( d_output );
    for ( int i = 0; i < 6; i++ )
        std::printf( "%d\n", h_output[i] );
    return ( EXIT_SUCCESS );
