In building OpenCV 3.0 from source (from GitHub master), I’m getting an issue which seems to be related to the CUDA toolkit and not to OpenCV itself. I have an 860M on Ubuntu 16.04 with driver 367.18 and CUDA toolkit 8.0. Am I right in saying that this is an error with the toolkit itself, or am I doing something incorrectly?
Build Command:
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D OPENCV_EXTRA_MODULES_PATH=/home/hades/Downloads/opencv/opencv_contrib/modules -D PYTHON3_EXECUTABLE=/usr/bin/python3 -D PYTHON_INCLUDE_DIR=/usr/include/python3.5 -D PYTHON_INCLUDE_DIR2=/usr/include/x86_64-linux-gnu/python3.5m -D PYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.5m.so -D PYTHON3_NUMPY_INCLUDE_DIRS=/usr/local/lib/python3.5/dist-packages/numpy/core/include -D WITH_TBB=ON -D ENABLE_FAST_MATH=1 -D CUDA_FAST_MATH=1 -D WITH_CUBLAS=1 -D CUDA_ARCH_BIN="5.0" -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=OFF /home/hades/Downloads/opencv/opencv
(Seemingly) relevant error portions, with full text below:
/usr/local/cuda-8.0/include/thrust/detail/reference.inl(127): error: no default constructor exists for class "thrust::detail::execute_with_allocator<cv::cuda::device::ThrustAllocator, thrust::system::cuda::detail::execute_on_stream_base>"
/usr/local/cuda-8.0/include/thrust/detail/reference.inl(98): error: no default constructor exists for class "thrust::detail::execute_with_allocator<cv::cuda::device::ThrustAllocator, thrust::system::cuda::detail::execute_on_stream_base>"
