Hello everybody,
I designed a board used aic31 and I2S0.I used a driver (not alsa structure) test the hardware is ok.Then I want to use the alsa structure code tlv320aic3x.c in kenerl.I changed the tegra186-quill-common.dtsi as follows
nvidia,audio-routing =
“z LINE2L”, “z IN”,
“z LINE2R”, “z IN”,
“z HPLOUT”, “z OUT”,
“z HPROUT”, “z OUT”
/* “x Headphone”, “x OUT”,
“x IN”, “x Mic”,
“y Headphone”, “y OUT”,
“y IN”, “y Mic”,
“z IN”, “z OUT”,
“m Headphone”, “m OUT”,
“m IN”, “m Mic”,
“n Headphone”, “n OUT”,
“n IN”, “n Mic”,
“o Headphone”, “o OUT”,
“o IN”, “o Mic”,
“a IN”, “a Mic”,
“b IN”, “b Mic”,
“c IN”, “c Mic”,
“d IN”, “d Mic”,
“e Headphone”, “e OUT”,
“e IN”, “e Mic”,
“d1 Headphone”, “d1 OUT”,
“d2 Headphone”, “d2 OUT”*/;
nvidia,xbar = <&tegra_axbar>;
rt565x_dai_link: nvidia,dai-link-1 {
link-name = "rt565x-playback";
cpu-dai = <&tegra_i2s1>;
codec-dai = <&spdif_dit0>;
cpu-dai-name = "I2S1";
codec-dai-name = "dit-hifi";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "x";
status = "okay";
I chaned the tegra_t186ref_mobile_rt565x.c as follws
SND_SOC_DAPM_LINE( “z IN”, NULL),
SND_SOC_DAPM_LINE( “z OUT”, NULL),SND_SOC_DAPM_LINE( “z IN”, NULL),
idx = tegra_machine_get_codec_dai_link_idx_t18x(“ti-capture”);
/* check if idx has valid number */
if (idx != -EINVAL) {
dai_params =
(struct snd_soc_pcm_stream *)card->rtd[idx].dai_link->params;
dai_params->rate_min = clk_rate;
dai_params->formats = (machine->fmt_via_kcontrol == 2) ?
(1ULL << SNDRV_PCM_FORMAT_S32_LE) : formats;
if (!machine->is_codec_dummy) {
/*err = snd_soc_dai_set_sysclk(card->rtd[idx].codec_dai, RT5659_SCLK_S_MCLK, clk_out_rate, SND_SOC_CLOCK_IN);*/
err = snd_soc_dai_set_sysclk(card->rtd[idx].codec_dai, 0, 12000000, SND_SOC_CLOCK_IN);
if (err < 0) {
dev_err(card->dev, "codec_dai clock not set clk_out_rate-%d\n", clk_out_rate);
return err;
I think the changes is ok.The boot log as follows
[09:14:16][ 2.827688] ****AIC31------aic3x_add_widgets
[09:14:16][ 2.832613] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[09:14:16][ 2.832681] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[09:14:16][ 2.832785] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[09:14:16][ 2.832848] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[09:14:16][ 2.832918] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[09:14:16][ 2.832989] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[09:14:16][ 2.833059] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[09:14:16][ 2.833152] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[09:14:16][ 2.833223] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[09:14:16][ 2.833293] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[09:14:16][ 2.833361] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[09:14:16][ 2.833442] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[09:14:16][ 2.833517] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[09:14:16][ 2.833588] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[09:14:16][ 2.833655] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[09:14:16][ 2.833728] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[09:14:16][ 2.833815] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[09:14:16][ 2.833881] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[09:14:16][ 2.833950] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[09:14:16][ 2.834020] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[09:14:16][ 2.837117] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[09:14:16][ 2.837206] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[09:14:16][ 2.837232] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[09:14:16][ 2.837253] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[09:14:16][ 2.840883] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[09:14:16][ 2.877680] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[09:14:16][ 2.878450] ****codec-dai “tlv320aic3x-hifi” registered
I enter the following command,it cannot capture sound,but no error reported.I don’t know how to eliminate the problem,thank you!
amixer -c tegrasndt186ref sset ‘ADMAIF1 Mux’ ‘I2S1’
amixer -c tegrasndt186ref sset ‘I2S1 Mux’ ‘ADMAIF1’
amixer -c tegrasndt186ref cset name=‘z Left PGA Mixer Line2L Switch’ 1
amixer -c tegrasndt186ref cset name=‘z Right PGA Mixer Line2R Switch’ 1
amixer -c tegrasndt186ref cset name=‘z Left HP Mixer Line2L Bypass Switch’ 1
amixer -c tegrasndt186ref cset name=‘z Right HP Mixer Line2L Bypass Switch’ 1
gst-launch-1.0 -v alsasrc ! “audio/x-raw,format=S16LE,layout=(string)interleaved,rate=(int)44100,channels=(int)2” ! queue ! audioconvert ! autoaudiosink
tegra186-quill-common.dtsi.txt (35.9 KB)
tegra_t186ref_mobile_rt565x.c (33.1 KB)
