tile clause error
I’m trying to use the tile clause with PGI 15.10,
and this is my code
#include <math.h>
#include <string.h>
#include "timer.h"
#include <stdio.h>
#define NN 1024
#define NM 1024
float A[NN][NM];
float Anew[NN][NM];
const int n = NN;
const int m = NM;
const int iter_max = 1000;
const double tol = 1.0e-6;
double error     = 1.0;
void testfunction()
    error = 0.0;
     #pragma acc kernels loop tile(8, 8)
    for( int j = 1; j < n-1; j++)
        //#pragma acc loop gang(8) vector(32)
        for( int i = 1; i < m-1; i++ )
            Anew[j][i] = 0.25 * ( A[j][i+1] + A[j][i-1]
                                + A[j-1][i] + A[j+1][i]);
            error = fmax( error, fabs(Anew[j][i] - A[j][i]));
            A[j][i] = Anew[j][i];
int main(int argc, char** argv)
    memset(A, 0, n * m * sizeof(float));
    memset(Anew, 0, n * m * sizeof(float));
    for (int j = 0; j < n; j++)
        A[j][0]    = 1.0;
        Anew[j][0] = 1.0;
    printf("Jacobi relaxation Calculation: %d x %d mesh\n", n, m);
    StartTimer();
    int iter = 0;
    #pragma acc data copy(A), create(Anew)
    while ( error > tol && iter < iter_max )
        testfunction();
        if(iter % 100 == 0) printf("%5d, %0.6f\n", iter, error);
        iter++;
    double runtime = GetTimer();
    printf(" total: %f s\n", runtime / 1000);
the complier reports
$ pgc++ -acc -Minfo=accel -ta=nvidia test2Dfunction_parallel.cpp -o acc2.out
"test2Dfunction_parallel.cpp", line 22: error: invalid text in pragma
"test2Dfunction_parallel.cpp", line 22: error: extra text after expected end
          of preprocessing directive
2 errors detected in the compilation of "test2Dfunction_parallel.cpp".
I have tried the #pragma acc parallel loop tile(8, 8), but it reports the same error.
Is the 15.10 support OpenACC 2.0 features? What about the tile clause?[/quote]
Hi cwu87488,
The C++ front-end was missing a few constructs including “tile”. These were added in the 16.4 release.
If you can, either upgrade 16.4 or use the C compiler, pgcc.
Hope this helps,
Mat
% pgcc -acc -V15.10 test.c -Minfo=accel
testfunction:
     22, Generating copyout(Anew[1:n-2][1:m-2])
         Generating copyin(A[:n][:m])
     23, Loop is parallelizable
     26, Loop is parallelizable
         Accelerator kernel generated
         Generating Tesla code
         23, #pragma acc loop gang, vector tile(8,8) /* blockIdx.x threadIdx.x */
         26,   /* blockIdx.x threadIdx.x tiled */
main:
     68, Generating copy(A[:][:])
         Generating create(Anew[:][:])
% pgc++ -acc test.cpp -V16.4 -Minfo=accel
testfunction():
     20, Generating copyout(Anew[1:1022][1:1022])
         Generating copyin(A[:][:])
main:
     69, Generating copy(A[:][:])
