Tile Operator in TensorRT 6
I want to implement Tile operator in TensorRT 6. I see that it is supported in 7, and Slice layer is been used along with the wrap mode set for implementation of Tile operator. However, 6 does not support Wrap mode for Slice layer so we cannot use the same method in 6.
I am looking for any alternate way of doing this.
Dear @roshanchaudhari,
Are you asking if there is any supported layers that can be used instead of tile operation?
Yes, are there any other layers which I can use to implement tile operator?
Unfortunately, you need to implement plugin layer op as it is not supported.
