When I get video from camera by (rtsp://admin:admin@192.168.1.64:554/cam/realmonitor?channel=1&subtype=2) ,it has this error. But is’ok for DS1.5.
deepstream-app -c deepstream_app_config_yoloV3.txt
platform:TX2 DS4.0
error:
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:149>: Pipeline running
Creating LL OSD context new
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
ERROR from tiled_display_tiler: GstNvTiler: FATAL ERROR; NvTiler::Composite failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvtiler/gstnvtiler.cpp(665): gst_nvmultistreamtiler_transform (): /GstPipeline:pipeline/GstBin:tiled_display_bin/GstNvMultiStreamTiler:tiled_display_tiler
Quitting
App run failed
config file:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
# uri=file://../../samples/streams/sample_1080p_h264.mp4
uri=rtsp://admin:admin@192.168.1.64:554/cam/realmonitor?channel=1&subtype=2
# uri=rtsp://admin:admin@192.168.1.64:554/cam/realmonitor?channel=1&subtype=2
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
