Hello @vchuang,
thanks a lot for the support and the answers, they were really helpful!
In the following you will find the answers to your questions and tests I performed after your feedback:
IMU Noise Parameters
To derive the IMU noise-model parameters I followed the IMU characterization procedure based on Allan deviation, specifically using the allan_ros2 repository, as described at step 3 of the Realsense VSLAM Tutorial.
Test with Reference Launch file and 30deg Mounted Camera
I initially performed two tests, one in static conditions and one moving and tilting the camera, with default launch file isaac_ros_visual_slam_realsense.launch.py:
# SPDX-FileCopyrightText: NVIDIA CORPORATION & AFFILIATES
# Copyright (c) 2021-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# SPDX-License-Identifier: Apache-2.0
import launch
from launch_ros.actions import ComposableNodeContainer, Node
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
"""Launch file which brings up visual slam node configured for RealSense."""
realsense_camera_node = Node(
name='camera',
namespace='camera',
package='realsense2_camera',
executable='realsense2_camera_node',
parameters=[{
'enable_infra1': True,
'enable_infra2': True,
'enable_color': False,
'enable_depth': False,
'depth_module.emitter_enabled': 0,
'depth_module.profile': '640x360x90',
'enable_gyro': True,
'enable_accel': True,
'gyro_fps': 200,
'accel_fps': 200,
'unite_imu_method': 2
visual_slam_node = ComposableNode(
name='visual_slam_node',
package='isaac_ros_visual_slam',
plugin='nvidia::isaac_ros::visual_slam::VisualSlamNode',
parameters=[{
'enable_image_denoising': False,
'rectified_images': True,
'enable_imu_fusion': True,
'gyro_noise_density': 0.000244,
'gyro_random_walk': 0.000019393,
'accel_noise_density': 0.001862,
'accel_random_walk': 0.003,
'calibration_frequency': 200.0,
'image_jitter_threshold_ms': 22.00,
'base_frame': 'camera_link',
'imu_frame': 'camera_gyro_optical_frame',
'enable_slam_visualization': True,
'enable_landmarks_view': True,
'enable_observations_view': True,
'camera_optical_frames': [
'camera_infra1_optical_frame',
'camera_infra2_optical_frame',
remappings=[
('visual_slam/image_0', 'camera/infra1/image_rect_raw'),
('visual_slam/camera_info_0', 'camera/infra1/camera_info'),
('visual_slam/image_1', 'camera/infra2/image_rect_raw'),
('visual_slam/camera_info_1', 'camera/infra2/camera_info'),
('visual_slam/imu', 'camera/imu'),
visual_slam_launch_container = ComposableNodeContainer(
name='visual_slam_launch_container',
namespace='',
package='rclcpp_components',
executable='component_container',
composable_node_descriptions=[visual_slam_node],
output='screen',
return launch.LaunchDescription([visual_slam_launch_container, realsense_camera_node])
Using the reference launch file the phenomenon seems to be solved both in static and dynamic conditions. For completeness, in the following I report logs and rosbags of the two tests with both horizontal and tilted camera:
- Tilted Camera (30deg downward)
admin@yahboom:/workspaces/isaac_ros-dev$ ros2 launch isaac_ros_visual_slam isaac_ros_visual_slam_realsense.launch.py
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2026-09-17-16-41-00-127320-yahboom-948907
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container-1]: process started with pid [948919]
[INFO] [realsense2_camera_node-2]: process started with pid [948921]
[component_container-1] [INFO] [1789656060.612594713] [visual_slam_launch_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_visual_slam/lib/libvisual_slam_node.so
[realsense2_camera_node-2] [INFO] [1789656060.656518184] [camera.camera]: RealSense ROS v4.51.1
[realsense2_camera_node-2] [INFO] [1789656060.658051511] [camera.camera]: Built with LibRealSense v2.55.1
[realsense2_camera_node-2] [INFO] [1789656060.658138458] [camera.camera]: Running with LibRealSense v2.55.1
[component_container-1] [INFO] [1789656060.836544454] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container-1] [INFO] [1789656060.836686667] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container-1] [INFO] [1789656060.917721237] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container-1] [INFO] [1789656060.922013785] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container-1] [INFO] [1789656060.930302074] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container-1] [INFO] [1789656060.944600020] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container-1] 2026-09-17 16:41:00.984 WARN external/com_nvidia_gxf/gxf/std/program.cpp@538: No GXF scheduler specified.
[component_container-1] [INFO] [1789656060.994531932] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container-1] [INFO] [1789656061.046728266] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1789656061.049473407] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1789656061.087843105] [visual_slam_node]: cuVSLAM version: 12.6
[realsense2_camera_node-2] [INFO] [1789656061.213575953] [camera.camera]: Device with serial number 338522301029 was found.
[realsense2_camera_node-2] [INFO] [1789656061.213740406] [camera.camera]: Device with physical ID 2-1.2-3 was found.
[realsense2_camera_node-2] [INFO] [1789656061.213764055] [camera.camera]: Device with name Intel RealSense D455 was found.
[realsense2_camera_node-2] [INFO] [1789656061.214559183] [camera.camera]: Device with port number 2-1.2 was found.
[realsense2_camera_node-2] [INFO] [1789656061.214638226] [camera.camera]: Device USB type: 3.2
[realsense2_camera_node-2] [INFO] [1789656061.221687308] [camera.camera]: getParameters...
[realsense2_camera_node-2] [INFO] [1789656061.231257876] [camera.camera]: JSON file is not provided
[realsense2_camera_node-2] [INFO] [1789656061.231363351] [camera.camera]: Device Name: Intel RealSense D455
[realsense2_camera_node-2] [INFO] [1789656061.231386040] [camera.camera]: Device Serial No: 338522301029
[realsense2_camera_node-2] [INFO] [1789656061.231400376] [camera.camera]: Device physical port: 2-1.2-3
[realsense2_camera_node-2] [INFO] [1789656061.231411928] [camera.camera]: Device FW version: 5.13.0.50
[realsense2_camera_node-2] [INFO] [1789656061.231422649] [camera.camera]: Device Product ID: 0x0B5C
[realsense2_camera_node-2] [INFO] [1789656061.231432665] [camera.camera]: Sync Mode: Off
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/visual_slam_node' in container '/visual_slam_launch_container'
[component_container-1] [INFO] [1789656061.256509728] [visual_slam_node]: Time taken by CUVSLAM_WarmUpGPU(): 0.168549
[realsense2_camera_node-2] [WARN] [1789656066.013255758] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [WARN] [1789656067.917882299] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [INFO] [1789656067.943307630] [camera.camera]: Stopping Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1789656068.347898892] [camera.camera]: Starting Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1789656068.453688211] [camera.camera]: Open profile: stream_type: Infra(1), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1789656068.458166718] [camera.camera]: Open profile: stream_type: Infra(2), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1789656068.466575074] [camera.camera]: Stopping Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1789656068.618050349] [camera.camera]: Starting Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1789656068.807783064] [camera.camera]: Open profile: stream_type: Accel(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1789656068.807956702] [camera.camera]: Open profile: stream_type: Gyro(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1789656068.811231203] [camera.camera]: RealSense Node Is Up!
[realsense2_camera_node-2] [WARN] [1789656068.847156922] [camera.camera]:
[component_container-1] [INFO] [1789656069.145781260] [visual_slam_node]: Initializing cuVSLAM.
[component_container-1] [INFO] [1789656069.146162519] [visual_slam_node]: Use use_gpu: true
[component_container-1] [INFO] [1789656069.146204665] [visual_slam_node]: Enable IMU Fusion: true
[component_container-1] [INFO] [1789656069.146223833] [visual_slam_node]: gyroscope_noise_density: 0.000244
[component_container-1] [INFO] [1789656069.146240314] [visual_slam_node]: gyroscope_random_walk: 0.000019
[component_container-1] [INFO] [1789656069.146253242] [visual_slam_node]: accelerometer_noise_density: 0.001862
[component_container-1] [INFO] [1789656069.146265307] [visual_slam_node]: accelerometer_random_walk: 0.003000
[component_container-1] [INFO] [1789656069.146276059] [visual_slam_node]: frequency: 200.000000
[component_container-1] [INFO] [1789656069.278950049] [visual_slam_node]: Time taken by CUVSLAM_CreateTracker(): 0.132660
[component_container-1] [INFO] [1789656069.281590547] [visual_slam_node]: cuVSLAM tracker was successfully initialized.
[realsense2_camera_node-2] [WARN] [1789656069.375314181] [camera.camera]: XXX Hardware Notification:Motion Module failure,1.78966e+12,Error,Hardware Error
[realsense2_camera_node-2] [WARN] [1789656069.375474218] [camera.camera]: Hardware Notification:Motion Module failure,1.78966e+12,Error,Hardware Error
[component_container-1] [WARN] [1789656069.403304198] [visual_slam_node]: Delta between current and previous frame [76.372736 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.455507349] [visual_slam_node]: Delta between current and previous frame [238.631680 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.465381670] [visual_slam_node]: Delta between current and previous frame [79.492096 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.475990958] [visual_slam_node]: Delta between current and previous frame [80.017920 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.492504781] [visual_slam_node]: Delta between current and previous frame [79.932928 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.505143667] [visual_slam_node]: Delta between current and previous frame [78.777344 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.520906267] [visual_slam_node]: Delta between current and previous frame [76.567808 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.559058871] [visual_slam_node]: Delta between current and previous frame [76.805632 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.624004015] [visual_slam_node]: Delta between current and previous frame [75.726080 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.675375619] [visual_slam_node]: Delta between current and previous frame [75.035648 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.741818986] [visual_slam_node]: Delta between current and previous frame [74.106624 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.818347624] [visual_slam_node]: Delta between current and previous frame [73.254912 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.886038357] [visual_slam_node]: Delta between current and previous frame [72.482816 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656069.959979812] [visual_slam_node]: Delta between current and previous frame [71.554816 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.018261774] [visual_slam_node]: Delta between current and previous frame [70.899712 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.084412555] [visual_slam_node]: Delta between current and previous frame [70.401536 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.160735971] [visual_slam_node]: Delta between current and previous frame [69.781760 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.245450879] [visual_slam_node]: Delta between current and previous frame [69.166080 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.309292405] [visual_slam_node]: Delta between current and previous frame [68.526080 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.352266597] [visual_slam_node]: Delta between current and previous frame [67.837952 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.427941865] [visual_slam_node]: Delta between current and previous frame [67.152640 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.475934261] [visual_slam_node]: Delta between current and previous frame [66.464768 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.549475063] [visual_slam_node]: Delta between current and previous frame [65.779456 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.640779199] [visual_slam_node]: Delta between current and previous frame [65.091584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.695086190] [visual_slam_node]: Delta between current and previous frame [64.406016 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.751467453] [visual_slam_node]: Delta between current and previous frame [63.719424 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.815935751] [visual_slam_node]: Delta between current and previous frame [63.031808 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.895158520] [visual_slam_node]: Delta between current and previous frame [62.345728 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656070.973544176] [visual_slam_node]: Delta between current and previous frame [61.658880 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.018356986] [visual_slam_node]: Delta between current and previous frame [60.972544 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.107546880] [visual_slam_node]: Delta between current and previous frame [60.285440 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.168077295] [visual_slam_node]: Delta between current and previous frame [59.599616 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.222089397] [visual_slam_node]: Delta between current and previous frame [58.912000 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.287955434] [visual_slam_node]: Delta between current and previous frame [68.199936 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.355897983] [visual_slam_node]: Delta between current and previous frame [67.293952 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.416510673] [visual_slam_node]: Delta between current and previous frame [67.116800 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.493113554] [visual_slam_node]: Delta between current and previous frame [66.937600 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.572746192] [visual_slam_node]: Delta between current and previous frame [66.760192 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.633899699] [visual_slam_node]: Delta between current and previous frame [66.580992 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.688731314] [visual_slam_node]: Delta between current and previous frame [66.403840 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.763900871] [visual_slam_node]: Delta between current and previous frame [66.224384 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.841427780] [visual_slam_node]: Delta between current and previous frame [66.046976 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.898126173] [visual_slam_node]: Delta between current and previous frame [65.868288 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656071.973288561] [visual_slam_node]: Delta between current and previous frame [65.690624 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.029190066] [visual_slam_node]: Delta between current and previous frame [65.511168 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.093002439] [visual_slam_node]: Delta between current and previous frame [65.334272 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.149192304] [visual_slam_node]: Delta between current and previous frame [65.155840 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.209593724] [visual_slam_node]: Delta between current and previous frame [64.976896 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.282733681] [visual_slam_node]: Delta between current and previous frame [64.943360 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.344434949] [visual_slam_node]: Delta between current and previous frame [64.438016 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.416338997] [visual_slam_node]: Delta between current and previous frame [64.211968 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.485933981] [visual_slam_node]: Delta between current and previous frame [63.983872 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.553789519] [visual_slam_node]: Delta between current and previous frame [63.757824 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.620769318] [visual_slam_node]: Delta between current and previous frame [63.529728 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.692105700] [visual_slam_node]: Delta between current and previous frame [63.303680 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.754861144] [visual_slam_node]: Delta between current and previous frame [63.075584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.817585388] [visual_slam_node]: Delta between current and previous frame [62.849536 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.888246197] [visual_slam_node]: Delta between current and previous frame [62.621696 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656072.957208425] [visual_slam_node]: Delta between current and previous frame [62.395392 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.019226183] [visual_slam_node]: Delta between current and previous frame [62.167296 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.087560392] [visual_slam_node]: Delta between current and previous frame [61.941504 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.146345921] [visual_slam_node]: Delta between current and previous frame [61.713408 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.210230777] [visual_slam_node]: Delta between current and previous frame [61.486848 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.277795938] [visual_slam_node]: Delta between current and previous frame [63.771648 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.344958046] [visual_slam_node]: Delta between current and previous frame [65.989632 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.414040695] [visual_slam_node]: Delta between current and previous frame [65.941760 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.475989106] [visual_slam_node]: Delta between current and previous frame [65.892864 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.547678299] [visual_slam_node]: Delta between current and previous frame [65.845760 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.618275170] [visual_slam_node]: Delta between current and previous frame [65.797120 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656073.690226066] [visual_slam_node]: Delta between current and previous frame [65.750016 ms] is above threshold [22.000000 ms]
ROSBAG:
- Horizontal Camera
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2026-09-17-16-47-22-516586-yahboom-967682
[INFO] [component_container-1]: process started with pid [967694]
[INFO] [realsense2_camera_node-2]: process started with pid [967696]
[component_container-1] [INFO] [1789656442.994399779] [visual_slam_launch_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_visual_slam/lib/libvisual_slam_node.so
[realsense2_camera_node-2] [INFO] [1789656443.023088026] [camera.camera]: RealSense ROS v4.51.1
[realsense2_camera_node-2] [INFO] [1789656443.023357474] [camera.camera]: Built with LibRealSense v2.55.1
[realsense2_camera_node-2] [INFO] [1789656443.023387491] [camera.camera]: Running with LibRealSense v2.55.1
[component_container-1] [INFO] [1789656443.172154585] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container-1] [INFO] [1789656443.176938157] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::visual_slam::VisualSlamNode>
[component_container-1] [INFO] [1789656443.228440868] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container-1] [INFO] [1789656443.232555172] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container-1] [INFO] [1789656443.239549020] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container-1] [INFO] [1789656443.247102821] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container-1] 2026-09-17 16:47:23.266 WARN external/com_nvidia_gxf/gxf/std/program.cpp@538: No GXF scheduler specified.
[component_container-1] [INFO] [1789656443.266894217] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container-1] [INFO] [1789656443.277457199] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1789656443.279704021] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1789656443.406609735] [visual_slam_node]: cuVSLAM version: 12.6
[component_container-1] [INFO] [1789656443.536273134] [visual_slam_node]: Time taken by CUVSLAM_WarmUpGPU(): 0.129556
[realsense2_camera_node-2] [INFO] [1789656443.611951569] [camera.camera]: Device with serial number 338522301029 was found.
[realsense2_camera_node-2] [INFO] [1789656443.612128823] [camera.camera]: Device with physical ID 2-1.2-3 was found.
[realsense2_camera_node-2] [INFO] [1789656443.612148664] [camera.camera]: Device with name Intel RealSense D455 was found.
[realsense2_camera_node-2] [INFO] [1789656443.612605958] [camera.camera]: Device with port number 2-1.2 was found.
[realsense2_camera_node-2] [INFO] [1789656443.612643783] [camera.camera]: Device USB type: 3.2
[realsense2_camera_node-2] [INFO] [1789656443.627294604] [camera.camera]: getParameters...
[realsense2_camera_node-2] [INFO] [1789656443.641338942] [camera.camera]: JSON file is not provided
[realsense2_camera_node-2] [INFO] [1789656443.641456545] [camera.camera]: Device Name: Intel RealSense D455
[realsense2_camera_node-2] [INFO] [1789656443.641478946] [camera.camera]: Device Serial No: 338522301029
[realsense2_camera_node-2] [INFO] [1789656443.641494210] [camera.camera]: Device physical port: 2-1.2-3
[realsense2_camera_node-2] [INFO] [1789656443.641505123] [camera.camera]: Device FW version: 5.13.0.50
[realsense2_camera_node-2] [INFO] [1789656443.641514915] [camera.camera]: Device Product ID: 0x0B5C
[realsense2_camera_node-2] [INFO] [1789656443.641525315] [camera.camera]: Sync Mode: Off
[realsense2_camera_node-2] [WARN] [1789656448.389189457] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [WARN] [1789656450.561005892] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [INFO] [1789656450.625764469] [camera.camera]: Stopping Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1789656451.071914546] [camera.camera]: Starting Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1789656451.210933914] [camera.camera]: Open profile: stream_type: Infra(1), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1789656451.211100576] [camera.camera]: Open profile: stream_type: Infra(2), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1789656451.211237380] [camera.camera]: Stopping Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1789656451.376662684] [camera.camera]: Starting Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1789656451.466966691] [camera.camera]: Open profile: stream_type: Accel(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1789656451.467128456] [camera.camera]: Open profile: stream_type: Gyro(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1789656451.476429768] [camera.camera]: RealSense Node Is Up!
[realsense2_camera_node-2] [WARN] [1789656451.492304531] [camera.camera]:
[component_container-1] [INFO] [1789656451.816164876] [visual_slam_node]: Initializing cuVSLAM.
[component_container-1] [INFO] [1789656451.818669753] [visual_slam_node]: Use use_gpu: true
[component_container-1] [INFO] [1789656451.821581203] [visual_slam_node]: Enable IMU Fusion: true
[component_container-1] [INFO] [1789656451.823074433] [visual_slam_node]: gyroscope_noise_density: 0.000244
[component_container-1] [INFO] [1789656451.823157956] [visual_slam_node]: gyroscope_random_walk: 0.000019
[component_container-1] [INFO] [1789656451.823774167] [visual_slam_node]: accelerometer_noise_density: 0.001862
[component_container-1] [INFO] [1789656451.823827449] [visual_slam_node]: accelerometer_random_walk: 0.003000
[component_container-1] [INFO] [1789656451.823971101] [visual_slam_node]: frequency: 200.000000
[component_container-1] [INFO] [1789656451.981651270] [visual_slam_node]: Time taken by CUVSLAM_CreateTracker(): 0.157648
[component_container-1] [INFO] [1789656451.983476031] [visual_slam_node]: cuVSLAM tracker was successfully initialized.
[realsense2_camera_node-2] [WARN] [1789656452.080945827] [camera.camera]: XXX Hardware Notification:Motion Module failure,1.78966e+12,Error,Hardware Error
[realsense2_camera_node-2] [WARN] [1789656452.081095784] [camera.camera]: Hardware Notification:Motion Module failure,1.78966e+12,Error,Hardware Error
[component_container-1] [WARN] [1789656452.126282076] [visual_slam_node]: Delta between current and previous frame [93.784064 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.176880248] [visual_slam_node]: Delta between current and previous frame [178.763520 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.189778311] [visual_slam_node]: Delta between current and previous frame [87.819776 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.198930434] [visual_slam_node]: Delta between current and previous frame [86.777088 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.204629778] [visual_slam_node]: Delta between current and previous frame [83.918336 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.221975274] [visual_slam_node]: Delta between current and previous frame [82.386688 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.245657318] [visual_slam_node]: Delta between current and previous frame [80.689408 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.256651418] [visual_slam_node]: Delta between current and previous frame [78.986496 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.280883079] [visual_slam_node]: Delta between current and previous frame [77.239040 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.319765432] [visual_slam_node]: Delta between current and previous frame [75.529472 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.375168521] [visual_slam_node]: Delta between current and previous frame [73.863168 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.439584111] [visual_slam_node]: Delta between current and previous frame [72.660736 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.499109503] [visual_slam_node]: Delta between current and previous frame [71.377664 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.572836646] [visual_slam_node]: Delta between current and previous frame [70.375680 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.635984197] [visual_slam_node]: Delta between current and previous frame [69.443584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.723284816] [visual_slam_node]: Delta between current and previous frame [68.265984 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.767367810] [visual_slam_node]: Delta between current and previous frame [67.418880 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.833954380] [visual_slam_node]: Delta between current and previous frame [66.742272 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.901525908] [visual_slam_node]: Delta between current and previous frame [65.911040 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656452.998316324] [visual_slam_node]: Delta between current and previous frame [65.385216 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.039949290] [visual_slam_node]: Delta between current and previous frame [64.144384 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.116588299] [visual_slam_node]: Delta between current and previous frame [62.905856 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.177629322] [visual_slam_node]: Delta between current and previous frame [61.665024 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.241917196] [visual_slam_node]: Delta between current and previous frame [60.426240 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.315922844] [visual_slam_node]: Delta between current and previous frame [59.185664 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.381857778] [visual_slam_node]: Delta between current and previous frame [57.946880 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.443749866] [visual_slam_node]: Delta between current and previous frame [56.706304 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.516962977] [visual_slam_node]: Delta between current and previous frame [55.467520 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.584964343] [visual_slam_node]: Delta between current and previous frame [54.226688 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.642235041] [visual_slam_node]: Delta between current and previous frame [52.988160 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.704934323] [visual_slam_node]: Delta between current and previous frame [51.747584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.785894105] [visual_slam_node]: Delta between current and previous frame [50.508544 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.835861441] [visual_slam_node]: Delta between current and previous frame [49.268224 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.900675540] [visual_slam_node]: Delta between current and previous frame [52.634368 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656453.986034466] [visual_slam_node]: Delta between current and previous frame [67.235584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.043361870] [visual_slam_node]: Delta between current and previous frame [67.100416 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.116779115] [visual_slam_node]: Delta between current and previous frame [66.962944 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.171991542] [visual_slam_node]: Delta between current and previous frame [66.828032 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.245739709] [visual_slam_node]: Delta between current and previous frame [66.691584 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.301136653] [visual_slam_node]: Delta between current and previous frame [66.554624 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.368104899] [visual_slam_node]: Delta between current and previous frame [66.419456 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.437170041] [visual_slam_node]: Delta between current and previous frame [66.281984 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.510027461] [visual_slam_node]: Delta between current and previous frame [66.147328 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.571642805] [visual_slam_node]: Delta between current and previous frame [66.009600 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.639802032] [visual_slam_node]: Delta between current and previous frame [65.874688 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.718004801] [visual_slam_node]: Delta between current and previous frame [65.737472 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.787085368] [visual_slam_node]: Delta between current and previous frame [65.602304 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.851998766] [visual_slam_node]: Delta between current and previous frame [65.465088 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.908136565] [visual_slam_node]: Delta between current and previous frame [65.360384 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656454.968243031] [visual_slam_node]: Delta between current and previous frame [66.505216 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.034300944] [visual_slam_node]: Delta between current and previous frame [65.478912 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.111449217] [visual_slam_node]: Delta between current and previous frame [65.319424 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.172149045] [visual_slam_node]: Delta between current and previous frame [65.162752 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.255771341] [visual_slam_node]: Delta between current and previous frame [65.003264 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.315413824] [visual_slam_node]: Delta between current and previous frame [64.846080 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.372927666] [visual_slam_node]: Delta between current and previous frame [64.687104 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.450127620] [visual_slam_node]: Delta between current and previous frame [64.529664 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.510328552] [visual_slam_node]: Delta between current and previous frame [64.370688 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.585342647] [visual_slam_node]: Delta between current and previous frame [64.213248 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.635310335] [visual_slam_node]: Delta between current and previous frame [64.055296 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.704990249] [visual_slam_node]: Delta between current and previous frame [63.896064 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.783602118] [visual_slam_node]: Delta between current and previous frame [63.738624 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.863024861] [visual_slam_node]: Delta between current and previous frame [63.579648 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.919818232] [visual_slam_node]: Delta between current and previous frame [63.422208 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656455.971166507] [visual_slam_node]: Delta between current and previous frame [65.581824 ms] is above threshold [22.000000 ms]
[component_container-1] [WARN] [1789656456.043327297] [visual_slam_node]: Delta between current and previous frame [66.636032 ms] is above threshold [22.000000 ms]
ROSBAG:
By comparing the two launch files I assumed that the IMU noise-model parameters might be the issue, therefore I performed a new calibration again using allan_ros2, however I obtained the following similar to my original launch file:
#Accelerometer
accelerometer_noise_density: 0.0009432369231993402
accelerometer_random_walk: 6.940925150373459e-05
#Gyroscope
gyroscope_noise_density: 0.000189053232614812
gyroscope_random_walk: 9.206653051795942e-06
rostopic: '/camera/imu'
update_rate: 200.0
Questions
Why does my custom launch file produce this behavior when the reference launch file works correctly?
Could the IMU noise-model parameters still be causing this issue (e.g., scale factor mismatches or units expected by Isaac ROS), or should I focus on differences in node parameters/transforms between the two launch files?
Thanks again for your time and assistance! I look forward to hearing your thoughts.
