I would like to know how “nsys stats” reports the GPU time percentage number for kernels. Please see the following line:
Time(%) Total Time (ns) Instances Average Minimum Maximum Name
51.8 1,854,648,457 4,554 407,257.0 332,256 436,716 nbnxn_kernel_ElecEw_VdwLJFsw_F_cuda(cu_atomdata, cu_nbparam, Nbnxm::gpu_plist, bool)
So, it is 51.8%.
Now, looking at the picture below
https://pasteboard.co/Jr3CvTo.jpg
which is the output of nsys-ui, I guess the total time calculation should be
0.9990.5750.745*0.882=0.377
or 37.7%.
Am I right? What is missing here?
This is saying that the executions of this kernel represent 51.8% of the execution time of all the things in this report.
The help explains it better:
Note that the “Time(%)” column is calculated using a summation of the “Total Time” column, and represents that API call’s, kernel’s, or memory operation’s percent of the execution time of the APIs, kernels and memory operations listed, and not a percentage of the application wall or CPU execution time.
Here is the full help output:
$ nsys stats --help-reports apigpusum
apigpusum[:base] -- CUDA API & GPU Summary (CUDA API + kernels + memory ops)
base - Optional argument, if given, will cause summary to be over the
base name of the kernel, rather than the templated name.
Output: All time values given in nanoseconds
Time(%) : Percentage of "Total Time"
Total Time : The total time used by all executions of this kernel
Instances: The number of executions of this object
Average : The average execution time of this kernel
Minimum : The smallest execution time of this kernel
Maximum : The largest execution time of this kernel
Category : The category of the operation
Operation : The name of the kernel
This report provides a summary of CUDA API calls, kernels and memory
operations, and their execution times. Note that the "Time(%)"
column is calculated using a summation of the "Total Time" column,
and represents that API call's, kernel's, or memory operation's
CPU execution time.
This report combines data from the "cudaapisum", "gpukernsum", and
"gpumemsizesum" reports. It is very similar to profile section of
"nvprof --dependency-analysis".
But the difference between that and what I see in the nsys-ui is large. nsys-ui also says a kernel takes X percents in a stream and that stream takes Y percent and …
