Time stamp I2C communication and Latency
Hi, is there a way to timestamp I2C communication and how much latency is there between requesting a read and pulling the value?
hello lowellm,
may I know what’s the actual use-case, why don’t you using kernel API to evaluate the latency.
Hi sorry, I have been busy. If there is low latency between when an I2C function is called and when it outputs to the wire that would be ok I think. The issue is how much lag is there?
hello lowellm,
I don’t have numbers, but it’s depends-on how many data you’re going to send via I2C.
why don’t you evaluate the latency by using kernel APIs.
How would I do this?
hello lowellm,
here’s simple sample code snippet.
s64 ts_start = 0, ts_end =0;
ts_start = ktime_to_ms(ktime_get());
your_code{}
ts_end = ktime_to_ms(ktime_get());
pr_info("latency is %lld ms",  (ts_end - ts_start));
