Timeout in CUDA on GTX465 WinXp
I am using CUDA SDK 3.1 on MS VS2005 with GPU GTX465 1 GB. I have such a kernel function:
__global__ void CRT_GPU_2(float *A, float *X, float *Y, float *Z, float *pIntensity, float *firstTime, float *pointsNumber)
int holo_x = blockIdx.x*20 + threadIdx.x;
  int holo_y = blockIdx.y*20 + threadIdx.y;
float k=2.0f*3.14f/0.000000054f;
if (firstTime[0]==1.0f)
   pIntensity[holo_x+holo_y*MAX_FINAL_X]=0.0f;
for (int i=0; i<pointsNumber[0]; i++)
   pIntensity[holo_x+holo_y*MAX_FINAL_X]=pIntensity[holo_x+holo_y*MAX_FINAL_X]+A[i]*cosf(k*sqrtf(pow(holo_x-X[i],2.0f)+pow(holo_y-Y[i],2.0f)+pow(Z[i],2.0f)));
__syncthreads();
and this is function which calls kernel function:
extern "C" void go2(float *pDATA, float *X, float *Y, float *Z, float *pIntensity, float *firstTime, float *pointsNumber)
 dim3 blockGridRows(MAX_FINAL_X/20,MAX_FINAL_Y/20);
 dim3 threadBlockRows(20, 20);
CRT_GPU_2<<<blockGridRows, threadBlockRows>>>(pDATA, X, Y, Z, pIntensity,firstTime, pointsNumber);
 CUT_CHECK_ERROR("multiplyNumbersGPU() execution failed\n");
 CUDA_SAFE_CALL( cudaThreadSynchronize() );
I am loading in loop all the paramteres to this function (for example 4096 elements for each parameter in one loop iteration). In total I want to make this kernel for 32768 elements for each parameter after all loop iterations.
The MAX_FINAL_X is 1920 and MAX_FINAL_Y is 1080.
When I am starting alghoritm first iteration goes very fast and after one or two iteration more I get information about CUDA timeout error. I used this alghoritm on GPU gtx260 and it was doing better as far as I remember…
Could You help me… maybe I am doing some mistake according to new Fermi arch in this algorithm?
I solved problem with timeout… I had a mistake in loading pointsNumber parameter (it was growing with each iteration) and I have limited number of points in each iteration to 2048… maybe there is a way to upload more points without timeout issue?
