I’m having an issue while trying to flash Jetpack 4.2.1 (AND only this specific Jetpack version) on some jetson (TX2).
With “some jetson” i mean a specific serialnumber range.
It works with S/N 14244 YYYY XXXX
It does not work with S/N 14241 YYYY XXXX and S/N 14242 YYYY XXXX
We have about 60 Jetsons within these prefix ranges, which are not working with 4.2.1
What does the error look like:
[ 9.8769 ]
[ 9.8799 ] tegrarcm_v2 --boot recovery
[ 9.8827 ] Applet version 01.00.0000
[ 10.0664 ]
[ 11.0682 ] tegrarcm_v2 --isapplet
[ 11.7395 ]
[ 11.7426 ] tegradevflash_v2 --iscpubl
[ 11.7439 ] Cannot Open USB
[ 12.1253 ]
[ 13.1296 ] tegrarcm_v2 --isapplet
And then the process is just stuck …
After a while i see a timeout for the usb access with dmesg:
[ 2950.515574] INFO: task tegrarcm_v2:8533 blocked for more than 245 seconds.
[ 2950.515582] Tainted: P OE 5.4.0-77-lowlatency #86~18.04.1-Ubuntu
[ 2950.515585] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 2950.515588] tegrarcm_v2 D 0 8533 8371 0x20020000
[ 2950.515594] Call Trace:
[ 2950.515605] __schedule+0x295/0x740
[ 2950.515610] schedule+0x3a/0xc0
[ 2950.515615] schedule_timeout+0x15b/0x330
[ 2950.515623] ? __next_timer_interrupt+0xe0/0xe0
[ 2950.515628] wait_for_completion_timeout+0xa5/0x130
[ 2950.515632] ? wake_up_q+0x80/0x80
[ 2950.515640] usb_start_wait_urb+0xe3/0x180
[ 2950.515647] usb_bulk_msg+0xb8/0x160
[ 2950.515653] proc_bulk+0x257/0x3a0
[ 2950.515660] usbdev_do_ioctl+0x93d/0x1480
[ 2950.515666] ? handle_mm_fault+0xd5/0x210
[ 2950.515672] usbdev_compat_ioctl+0x10/0x20
[ 2950.515678] __ia32_compat_sys_ioctl+0x105/0x230
[ 2950.515686] do_int80_syscall_32+0x5b/0x130
[ 2950.515692] entry_INT80_compat+0x85/0x90
[ 2950.515696] RIP: 0023:0x807a454
[ 2950.515706] Code: Bad RIP value.
[ 2950.515709] RSP: 002b:00000000ffcb2478 EFLAGS: 00000283 ORIG_RAX: 0000000000000036
[ 2950.515714] RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00000000c0105502
[ 2950.515716] RDX: 00000000ffcb24a0 RSI: 0000000000000010 RDI: 0000000008ac3688
[ 2950.515718] RBP: 00000000ffcb2500 R08: 0000000000000000 R09: 0000000000000000
[ 2950.515719] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 2950.515721] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
Does any know a way to convince the jetsons to be flashable?
Some more information:
- We are not flashing from a VM
- Other JetPack versions are flashable (for example 3.3.3 and 4.4.1 work just fine on both S/N ranges), however our customer is tied to JetPack 4.2.1 dependencies.
- The cable works just fine (i use the same cable as above)
- The error appear when using flash.sh and sdkmanager
- I tried using the flashing applications/scripts from working Jetpack versions, but no luck (or maybe i replace the wrong ones).
- It is stuck in check_ismb1() in tegraflash_internal.py (which in turn is called by tegraflash_poll_applet_bl().
Thanks in advance!
error_log_flash.txt (23.9 KB)
usberror (3.5 KB)
