Using omni.kit.commands.execute("Ros2BridgeUsePhysicsStepSimTime",use_physics_step_sim_time=True)
, the /clock topic did publish the physics step sim time successfully. However the timestamp in the joint states topic is wrong. the screenshot is as attached. [Left - /joint_states, /tf topic, Right - /clock topic]. ROS1 Bridge does not have this bug. /tf_static doesn’t seem to use sim time.
Wrong: using physics time (i.e. use_physics_step_sim_time=True), the sec is assigned into nanosec
Correct: Using rendering time (i.e. use_physics_step_sim_time=False, which is the default behaviour)
Looking forward to the bug fixes on this. Thanks.
