I ran my gstreamer based app with heavy cpu/gpu load over night (normally it would cost 200% CPU, 70% GPU).
And every hour a ffmpeg task was scheduled for converting fmp4 file generated from my app to normal mp4 file.
I noticed that my app somehow experienced timestamp discontinuity issue if ffmpeg task was running.
The ffmpeg task would cost 70%~80% CPU load (1 core) and only last 2 minutes.
From the log of my app, it seems my app process was not scheduled by OS about 13 seconds from 2022-08-17 04:51:43 to 2022-08-17 04:51:56:
2022-08-17 04:51:43.217637 0x7ead254050 eswposepostproce INFO : fnum:110712 binfer:1 obj_meta:class id:82 obj id:798
2022-08-17 04:51:56.262183 0x7f80034b70 alsa WARN : xrun recovery -32: 断开的管道
2022-08-17 04:51:56.262305 0x7ead254050 eswposepostproce INFO : fnum:110712 binfer:1 obj_meta:class id:82 obj id:349
2022-08-17 04:51:56.262821 0x7ead2542d0 rtpjitterbuffer WARN : delta - skew: 0:00:02.541377196 too big, reset skew
2022-08-17 04:51:56.263547 0x7ead2542d0 rtpjitterbuffer WARN : delta - skew: 0:00:09.225789233 too big, reset skew
2022-08-17 04:51:56.262182 0x7e340314a0 alsa WARN : xrun recovery -32: 断开的管道
2022-08-17 04:51:56.265553 0x7eb015cf20 alsa WARN : xrun recovery -32: 断开的管道
2022-08-17 04:51:56.262825 0x7e28009590 rtpjitterbuffer WARN : delta - skew: 0:00:02.541426184 too big, reset skew
2022-08-17 04:51:56.273184 0x7e9664d140 alsa WARN : alsalib error: SNDRV_PCM_IOCTL_DELAY failed (-32): 断开的管道
2022-08-17 04:51:56.264079 0x7ea42315e0 alsa WARN : xrun recovery -32: 断开的管道
2022-08-17 04:51:56.284024 0x7ea4231f70 audioresample WARN : encountered timestamp discontinuity of 527732 samples = 0:00:11.966712018
2022-08-17 04:51:56.288230 0x7e28009590 rtpjitterbuffer WARN : delta - skew: 0:00:09.239380283 too big, reset skew
I found following OC alarming traces from syslog:
Aug 17 04:51:34 linux kernel: [149545.809189] soctherm: OC ALARM 0x00000001
Aug 17 04:51:35 linux kernel: [149546.925513] FAN rising trip_level:4 cur_temp:67700 trip_temps[5]:140000
Aug 17 04:51:36 linux kernel: [149547.320371] soctherm: OC ALARM 0x00000001
Aug 17 04:51:37 linux kernel: [149548.342868] soctherm: OC ALARM 0x00000001
Aug 17 04:51:38 linux kernel: [149549.723101] soctherm: OC ALARM 0x00000001
Aug 17 04:51:39 linux kernel: [149550.285753] FAN rising trip_level:4 cur_temp:67500 trip_temps[5]:140000
Aug 17 04:51:39 linux kernel: [149551.011665] soctherm: OC ALARM 0x00000001
Aug 17 04:51:40 linux kernel: [149551.405562] FAN rising trip_level:4 cur_temp:67700 trip_temps[5]:140000
Aug 17 04:51:40 linux kernel: [149552.019702] soctherm: OC ALARM 0x00000001
Aug 17 04:51:42 linux kernel: [149553.216657] soctherm: OC ALARM 0x00000001
Aug 17 04:51:47 linux kernel: [149558.125553] FAN rising trip_level:4 cur_temp:66250 trip_temps[5]:140000
Aug 17 04:51:50 linux kernel: [149561.485563] FAN rising trip_level:4 cur_temp:65750 trip_temps[5]:140000
Aug 17 04:51:54 linux kernel: [149565.965544] FAN rising trip_level:4 cur_temp:65550 trip_temps[5]:140000
More info :
I already changed the OC alert limit to 5000 mA.
To gain max performance, we enabled jetson_clocks and set VIC clock to max freq in 20W 6 core mode.
So how to fix the discontinuity issue?
Is it caused by the OC ALARM?
It could be. But it is unlikely to check if we cannot reproduce the issue locally.
Could you share the application and steps to check this issue?
Hi WayneWWW,
It’s not easy to provide our app at this time but I got some jtop statistics from my colleague.
Sorry that I can’t upload the file so I just paste here.
The ffmpeg task started at 4:51:07.
And I can see that there’s sudden CPU drop, power drop, NVENC shutoff and NVDEC shut off at 4:51:44 which basically match what I saw in the log of my APP.
Could you please help clarify this strange behavior?
Is there any OC handling here by Nvidia?
Thanks a lot.
time
uptime
jetson_clocks
nvp model
CPU1
CPU2
CPU3
CPU4
CPU5
CPU6
GPU
MTS FG
MTS BG
RAM
EMC
SWAP
APE
NVENC
NVDEC
NVJPG
fan
Temp AO
Temp AUX
Temp CPU
Temp GPU
Temp thermal
power cur
power avg
4:51:07 AM
1 day, 17:31:57.600000
ON
MODE_20W_6CORE
97
93
93
94
93
93
38
3
3
5086188
5086188
1162
150
729
793
OFF
100
66.5
66.5
69.5
67.5
68.05
15515
15239
4:51:07 AM
1 day, 17:31:58.300000
ON
MODE_20W_6CORE
97
91
97
97
91
95
41
3
3
5087076
5087076
1162
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
16111
15239
4:51:08 AM
1 day, 17:31:58.850000
ON
MODE_20W_6CORE
87
90
96
100
88
87
60
0
0
5043932
5043932
1162
150
729
793
OFF
100
66.5
66
69
68
67.85
16392
15239
4:51:08 AM
1 day, 17:31:59.400000
ON
MODE_20W_6CORE
83
82
81
82
81
87
26
2
2
5052328
5052328
1162
150
729
793
OFF
100
66.5
66
69.5
68
67.5
15813
15239
4:51:09 AM
1 day, 17:31:59.940000
ON
MODE_20W_6CORE
82
73
76
69
78
72
77
2
2
5053452
5053452
1162
150
729
793
OFF
100
66.5
66
69
68
67.5
15515
15239
4:51:09 AM
1 day, 17:32:00.510000
ON
MODE_20W_6CORE
83
84
75
75
74
79
27
2
2
5055756
5055756
1162
150
729
793
OFF
100
66.5
67
69
68
67.65
15344
15239
4:51:10 AM
1 day, 17:32:01.050000
ON
MODE_20W_6CORE
83
79
81
75
90
81
37
2
2
5071992
5071992
1162
150
729
793
OFF
100
66.5
66
69
68
67.65
15770
15239
4:51:11 AM
1 day, 17:32:01.640000
ON
MODE_20W_6CORE
85
82
90
84
85
90
88
2
2
5062572
5062572
1162
150
729
793
OFF
100
66.5
66
69.5
68
67.9
15279
15239
4:51:11 AM
1 day, 17:32:02.200000
ON
MODE_20W_6CORE
91
85
89
85
81
83
23
2
2
5066432
5066432
1162
150
729
793
OFF
100
66.5
66
69.5
67.5
67.9
15813
15239
4:51:12 AM
1 day, 17:32:02.770000
ON
MODE_20W_6CORE
83
87
89
78
89
89
68
2
2
5067700
5067700
1162
150
729
793
OFF
100
66.5
66.5
69.5
68
67.65
15941
15239
4:51:12 AM
1 day, 17:32:03.500000
ON
MODE_20W_6CORE
91
86
95
89
91
89
39
3
3
5063640
5063640
1162
150
729
793
OFF
100
66.5
66.5
69.5
68
67.65
15813
15239
4:51:13 AM
1 day, 17:32:04.210000
ON
MODE_20W_6CORE
97
97
97
91
90
94
99
3
3
5065032
5065032
1162
150
729
793
OFF
100
66.5
66
69.5
68
67.65
15813
15239
4:51:14 AM
1 day, 17:32:04.910000
ON
MODE_20W_6CORE
97
94
95
90
92
92
38
3
3
5065844
5065844
1163
150
729
793
OFF
100
66.5
66.5
69.5
68
67.65
16111
15239
4:51:14 AM
1 day, 17:32:05.570000
ON
MODE_20W_6CORE
94
93
92
90
94
97
24
2
2
5070044
5070044
1163
150
729
793
OFF
100
66.5
66
69.5
68
67.65
15813
15239
4:51:15 AM
1 day, 17:32:06.260000
ON
MODE_20W_6CORE
95
94
97
91
91
92
66
2
2
5067776
5067776
1164
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15898
15239
4:51:16 AM
1 day, 17:32:07.040000
ON
MODE_20W_6CORE
94
93
98
95
97
95
67
3
3
5066824
5066824
1164
150
729
793
OFF
100
66.5
66.5
69.5
68
67.65
15685
15239
4:51:17 AM
1 day, 17:32:07.830000
ON
MODE_20W_6CORE
98
97
97
93
96
93
56
3
3
5067592
5067592
1165
150
729
793
OFF
100
66.5
67
69.5
68
67.65
15941
15239
4:51:18 AM
1 day, 17:32:08.650000
ON
MODE_20W_6CORE
100
97
92
93
90
95
16
3
3
5066688
5066688
1166
150
729
793
OFF
100
66.5
66
69.5
68
67.65
15643
15239
4:51:18 AM
1 day, 17:32:09.410000
ON
MODE_20W_6CORE
100
97
91
92
94
96
21
3
3
5068032
5068032
1166
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
16154
15239
4:51:19 AM
1 day, 17:32:10.160000
ON
MODE_20W_6CORE
98
98
94
94
93
92
21
3
3
5066112
5066112
1169
150
729
793
OFF
100
66.5
66.5
69
67.5
67.85
15709
15239
4:51:20 AM
1 day, 17:32:10.830000
ON
MODE_20W_6CORE
98
98
90
87
95
95
49
2
2
5067440
5067440
1169
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15965
15239
4:51:21 AM
1 day, 17:32:11.610000
ON
MODE_20W_6CORE
98
97
97
92
97
97
43
3
3
5065040
5065040
1169
150
729
793
OFF
100
66.5
66
69.5
68
67.7
15837
15239
4:51:21 AM
1 day, 17:32:12.430000
ON
MODE_20W_6CORE
96
96
92
93
96
97
29
3
3
5066496
5066496
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.7
15941
15239
4:51:22 AM
1 day, 17:32:13.170000
ON
MODE_20W_6CORE
95
91
93
93
97
96
21
2
2
5069748
5069748
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15856
15239
4:51:23 AM
1 day, 17:32:13.890000
ON
MODE_20W_6CORE
97
94
94
92
95
98
64
3
3
5069260
5069260
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
68
16434
15239
4:51:24 AM
1 day, 17:32:14.680000
ON
MODE_20W_6CORE
96
98
94
89
97
96
69
3
3
5070952
5070952
1170
150
729
793
OFF
100
66.5
66.5
69.5
68.5
67.85
16239
15239
4:51:24 AM
1 day, 17:32:15.280000
ON
MODE_20W_6CORE
96
96
91
91
98
98
58
3
3
5078312
5078312
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15984
15239
4:51:25 AM
1 day, 17:32:15.870000
ON
MODE_20W_6CORE
90
87
85
78
91
86
35
3
3
5080628
5080628
1170
150
729
793
OFF
100
66.5
67.5
69.5
68
68
15856
15239
4:51:25 AM
1 day, 17:32:16.460000
ON
MODE_20W_6CORE
82
80
83
89
75
78
37
2
2
5079812
5079812
1170
150
729
793
OFF
100
66.5
66.5
69.5
68.5
68
15770
15239
4:51:26 AM
1 day, 17:32:17.010000
ON
MODE_20W_6CORE
81
69
70
75
80
72
25
2
2
5081560
5081560
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15387
15239
4:51:27 AM
1 day, 17:32:17.610000
ON
MODE_20W_6CORE
75
81
70
66
71
70
29
2
2
5080812
5080812
1170
150
729
793
OFF
100
66.5
66
69.5
68
67.85
15216
15239
4:51:27 AM
1 day, 17:32:18.260000
ON
MODE_20W_6CORE
84
85
83
86
84
87
25
2
2
5082036
5082036
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.85
15472
15239
4:51:28 AM
1 day, 17:32:18.960000
ON
MODE_20W_6CORE
94
92
92
91
94
97
37
3
3
5082180
5082180
1170
150
729
793
OFF
100
66
66.5
69.5
68.5
67.85
16239
15239
4:51:28 AM
1 day, 17:32:19.490000
ON
MODE_20W_6CORE
85
78
84
84
82
83
25
2
2
5078748
5078748
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
68
15515
15239
4:51:29 AM
1 day, 17:32:20.080000
ON
MODE_20W_6CORE
81
80
79
78
81
81
71
3
3
5076312
5076312
1170
150
729
793
OFF
100
66.5
66.5
69
68
68
15515
15239
4:51:30 AM
1 day, 17:32:20.650000
ON
MODE_20W_6CORE
82
78
81
76
73
74
69
2
2
5080512
5080512
1170
150
729
793
OFF
100
66.5
66.5
69.5
68.5
67.85
15557
15239
4:51:30 AM
1 day, 17:32:21.240000
ON
MODE_20W_6CORE
70
78
68
71
59
66
14
2
2
5080388
5080388
1170
150
729
793
OFF
100
66.5
66.5
69
68
67.85
15151
15239
4:51:31 AM
1 day, 17:32:21.770000
ON
MODE_20W_6CORE
66
67
62
56
61
67
66
2
2
5079860
5079860
1170
150
729
793
OFF
100
66.5
66.5
69
68.5
67.85
15066
15239
4:51:31 AM
1 day, 17:32:22.270000
ON
MODE_20W_6CORE
70
68
68
66
75
64
47
2
2
5075768
5075768
1170
150
729
793
OFF
100
66.5
66.5
69
68
67.85
15151
15239
4:51:32 AM
1 day, 17:32:22.800000
ON
MODE_20W_6CORE
80
73
79
76
78
76
61
2
2
5075972
5075972
1170
150
729
793
OFF
100
66.5
66.5
69
68.5
67.5
15557
15239
4:51:32 AM
1 day, 17:32:23.360000
ON
MODE_20W_6CORE
58
56
65
58
64
72
38
1
1
5080416
5080416
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
14640
15239
4:51:33 AM
1 day, 17:32:23.900000
ON
MODE_20W_6CORE
39
44
50
46
37
48
36
1
1
5079236
5079236
1170
150
OFF
793
OFF
100
66.5
66.5
69
67.5
67.4
12371
15239
4:51:33 AM
1 day, 17:32:24.480000
ON
MODE_20W_6CORE
59
51
50
50
50
59
39
1
1
5076468
5076468
1170
150
729
793
OFF
100
66.5
66
69
68
67.4
13049
15239
4:51:34 AM
1 day, 17:32:24.960000
ON
MODE_20W_6CORE
88
85
86
83
83
87
43
3
3
5078088
5078088
1170
150
729
793
OFF
100
66.5
66
69
68.5
67.5
15856
15239
4:51:34 AM
1 day, 17:32:25.570000
ON
MODE_20W_6CORE
74
63
72
66
77
70
36
2
2
5079952
5079952
1170
150
729
793
OFF
100
66.5
66
69
67.5
67.5
15321
15239
4:51:35 AM
1 day, 17:32:26.110000
ON
MODE_20W_6CORE
64
67
61
59
64
77
69
2
2
5079116
5079116
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
15406
15239
4:51:36 AM
1 day, 17:32:26.630000
ON
MODE_20W_6CORE
67
63
64
62
62
67
39
2
2
5078888
5078888
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
14853
15239
4:51:36 AM
1 day, 17:32:27.150000
ON
MODE_20W_6CORE
73
70
72
71
69
64
94
2
2
5075780
5075780
1170
150
729
793
OFF
100
66.5
66.5
69
68
67.7
15193
15239
4:51:37 AM
1 day, 17:32:27.700000
ON
MODE_20W_6CORE
77
71
74
70
69
78
28
2
2
5075888
5075888
1170
150
729
793
OFF
100
66.5
66
69
68
67.7
15193
15239
4:51:37 AM
1 day, 17:32:28.470000
ON
MODE_20W_6CORE
83
87
85
81
88
96
57
2
2
5077964
5077964
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.5
15941
15239
4:51:38 AM
1 day, 17:32:29.120000
ON
MODE_20W_6CORE
85
83
84
78
83
78
37
3
3
5077080
5077080
1170
150
729
793
OFF
100
66.5
66.5
69
68
67.5
15643
15239
4:51:39 AM
1 day, 17:32:29.800000
ON
MODE_20W_6CORE
75
76
78
76
76
75
67
2
2
5077396
5077396
1170
150
729
793
OFF
100
66.5
66
69
68
67.35
15449
15239
4:51:39 AM
1 day, 17:32:30.360000
ON
MODE_20W_6CORE
73
74
67
74
80
67
33
2
2
5078528
5078528
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
15364
15239
4:51:40 AM
1 day, 17:32:30.940000
ON
MODE_20W_6CORE
80
71
66
73
71
73
44
2
2
5078688
5078688
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
15279
15239
4:51:40 AM
1 day, 17:32:31.460000
ON
MODE_20W_6CORE
76
75
69
71
70
76
66
2
2
5074788
5074788
1170
150
729
793
OFF
100
66.5
66
69
68
67.7
15236
15239
4:51:41 AM
1 day, 17:32:32.020000
ON
MODE_20W_6CORE
81
77
78
73
80
74
22
2
2
5075432
5075432
1170
150
729
793
OFF
100
66.5
66
69
68
67.7
15321
15239
4:51:42 AM
1 day, 17:32:32.640000
ON
MODE_20W_6CORE
83
72
72
68
67
64
73
2
2
5077468
5077468
1170
150
729
793
OFF
100
66.5
66
69.5
68
67.65
15236
15239
4:51:42 AM
1 day, 17:32:33.270000
ON
MODE_20W_6CORE
71
80
75
64
71
75
23
2
2
5078292
5078292
1170
150
729
793
OFF
100
66.5
66.5
69.5
68
67.65
15534
15239
4:51:43 AM
1 day, 17:32:33.870000
ON
MODE_20W_6CORE
71
69
71
80
76
72
51
2
2
5080440
5080440
1170
150
729
793
OFF
100
66.5
66
69
68
67.5
15321
15239
4:51:43 AM
1 day, 17:32:34.450000
ON
MODE_20W_6CORE
70
58
56
58
74
69
18
2
2
5079880
5079880
1170
150
729
793
OFF
100
66.5
66
69
67.5
67.5
14683
15239
4:51:44 AM
1 day, 17:32:34.970000
ON
MODE_20W_6CORE
54
51
50
48
48
45
33
1
1
5078072
5078072
1170
150
OFF
793
OFF
100
66.5
66.5
68.5
67.5
67.2
12329
15239
4:51:44 AM
1 day, 17:32:35.500000
ON
MODE_20W_6CORE
58
52
49
40
50
49
0
1
1
5078516
5078516
1170
150
OFF
793
OFF
100
66.5
66
68
66.5
67.2
10940
15239
4:51:45 AM
1 day, 17:32:36.030000
ON
MODE_20W_6CORE
33
25
31
29
26
32
0
1
1
5082008
5082008
1170
150
OFF
OFF
OFF
100
66
66
68
66.5
66.75
9166
15239
4:51:45 AM
1 day, 17:32:36.570000
ON
MODE_20W_6CORE
26
20
17
20
22
18
0
0
0
5085580
5085580
1170
150
OFF
OFF
OFF
100
66
65.5
68
66
66.75
8258
15239
4:51:46 AM
1 day, 17:32:37.080000
ON
MODE_20W_6CORE
22
21
16
18
16
21
0
0
0
5081276
5081276
1170
150
OFF
OFF
OFF
100
66
65.5
67
66
66.1
7617
15238
4:51:47 AM
1 day, 17:32:37.600000
ON
MODE_20W_6CORE
40
33
28
26
21
25
0
1
1
5081304
5081304
1170
150
OFF
OFF
OFF
100
66
65.5
67.5
66
66.1
7827
15238
4:51:47 AM
1 day, 17:32:38.120000
ON
MODE_20W_6CORE
35
23
27
28
28
21
0
0
0
5085296
5085296
1170
150
OFF
OFF
OFF
100
65.5
65.5
67.5
66
66.1
8132
15238
4:51:48 AM
1 day, 17:32:38.650000
ON
MODE_20W_6CORE
26
19
21
18
12
13
0
0
0
5086176
5086176
1170
150
OFF
OFF
OFF
100
65.5
65.5
67
65.5
66.25
7785
15238
4:51:48 AM
1 day, 17:32:39.160000
ON
MODE_20W_6CORE
24
24
17
18
17
22
0
0
0
5083200
5083200
1170
150
OFF
OFF
OFF
100
65.5
65.5
67
65.5
66.25
7450
15238
4:51:49 AM
1 day, 17:32:39.680000
ON
MODE_20W_6CORE
37
27
28
30
34
24
0
0
0
5083032
5083032
1170
150
OFF
OFF
OFF
100
65.5
65
66.5
65.5
65.75
7827
15238
4:51:49 AM
1 day, 17:32:40.210000
ON
MODE_20W_6CORE
28
25
26
24
30
28
0
0
0
5086552
5086552
1170
150
OFF
OFF
OFF
100
65.5
65
67
65.5
65.75
8048
15238
4:51:50 AM
1 day, 17:32:40.730000
ON
MODE_20W_6CORE
20
14
12
17
17
16
0
0
0
5088948
5088948
1170
150
OFF
OFF
OFF
100
65
65
67
65.5
65.6
7659
15238
4:51:50 AM
1 day, 17:32:41.240000
ON
MODE_20W_6CORE
28
20
22
22
18
17
0
0
0
5087064
5087064
1170
150
OFF
OFF
OFF
100
65
65
66.5
65.5
65.6
7450
15238
4:51:51 AM
1 day, 17:32:41.760000
ON
MODE_20W_6CORE
32
30
32
23
25
30
0
0
0
5088016
5088016
1170
150
OFF
OFF
OFF
100
65
65
66.5
65
65.75
7785
15237
4:51:51 AM
1 day, 17:32:42.280000
ON
MODE_20W_6CORE
30
29
30
18
24
20
0
0
0
5088768
5088768
1170
150
OFF
OFF
OFF
100
65
65
67
65
65.75
7994
15237
4:51:52 AM
1 day, 17:32:42.810000
ON
MODE_20W_6CORE
20
14
22
13
11
12
0
0
0
5088608
5088608
1170
150
OFF
OFF
OFF
100
65
65
66.5
65.5
65.25
7617
15237
4:51:52 AM
1 day, 17:32:43.310000
ON
MODE_20W_6CORE
27
25
17
24
25
22
0
1
1
5089464
5089464
1170
150
OFF
OFF
OFF
100
65
64.5
66
65
65.25
7534
15237
4:51:53 AM
1 day, 17:32:43.830000
ON
MODE_20W_6CORE
38
29
24
27
28
28
0
1
1
5089372
5089372
1170
150
OFF
OFF
OFF
100
65
64.5
66
65
65.25
7827
15237
4:51:53 AM
1 day, 17:32:44.360000
ON
MODE_20W_6CORE
28
23
23
22
21
21
0
0
0
5091364
5091364
1170
150
OFF
OFF
OFF
100
64.5
64.5
66.5
65
65.25
7910
15237
4:51:54 AM
1 day, 17:32:44.880000
ON
MODE_20W_6CORE
22
18
14
15
10
6
0
0
0
5090304
5090304
1170
150
OFF
OFF
OFF
100
64.5
64.5
66.5
65
65.1
7450
15237
4:51:54 AM
1 day, 17:32:45.380000
ON
MODE_20W_6CORE
31
30
28
20
21
26
0
1
1
5089176
5089176
1170
150
OFF
OFF
OFF
100
64.5
64.5
66
65
65.1
7534
15237
4:51:55 AM
1 day, 17:32:45.900000
ON
MODE_20W_6CORE
40
36
38
37
37
30
30
1
1
5089364
5089364
1170
150
OFF
OFF
OFF
100
64.5
64.5
66.5
65.5
65.1
9755
15237
4:51:55 AM
1 day, 17:32:46.430000
ON
MODE_20W_6CORE
34
26
28
30
28
30
35
1
1
5091488
5091488
1170
150
OFF
OFF
OFF
100
64.5
64.5
66.5
65.5
65.55
10317
15237
4:51:56 AM
1 day, 17:32:46.960000
ON
MODE_20W_6CORE
28
20
27
23
19
19
0
1
1
5087136
5087136
1170
150
OFF
OFF
OFF
100
64.5
64.5
66.5
65
65.55
8816
15236
4:51:56 AM
1 day, 17:32:47.480000
ON
MODE_20W_6CORE
49
50
42
43
49
47
50
1
1
5083872
5083872
1170
150
729
793
OFF
100
64.5
64.5
67
65.5
65.25
9628
15236
Actually, the way to resolve this issue should be to prevent the OC throttling first and see if the CPU drop is related.
There is no magic trick for “OC throttling”, it is just throttling the cpu/gpu/emc clock freq, so it has chance to be related to what you saw.
But the point is if your usecase would exceed the power budget from any kind of combination in the power estimator, it means your usecase is over what NX can support.
https://jetson-tools.nvidia.com/powerestimator/
Is there a formula or something similar that I can know that OC throttling is triggerred?
I’m just curious how Nvidia conclude that it’s time to do throttling stuff.
We have a bpmp controller inside the module. And when the OC is being detected, it will inform the kernel, so you see those logs in your dmesg. For any OC it got detected, it will throttle the performance.
But it is just a short time which is not easily to be observed. Only if your device keeps hitting the OC situation, and the throttle keeps triggering, so that you would notice a obvious perf drop.
Need to make some clarifications for this issue.
The OC throttling case also appears in jetpack4.4.1. The real cause that makes you feel this issue does not happen on jp4.4.1 is because there was no “OC alarm notification” mechanism implemented in jp4.4.1. Thus, jp4.5 and jp4.4.1 actually both have oc throtting.
The oc throtting is due the the hardware limitation of NX module. We currently set OC limit to 3.6A to protect the NX hardware.
The suggestion to prevent the OC throtting not…
system
Closed
September 7, 2022, 4:36am
9
