I’m writing object detection code using webcam and raspberry pi camera together. I used only jetson inference and utils in the code.
The problem is when I run the code after starting my Jetson nano, the program runs smoothly for a short time and then it shows errors in the terminal:
Error 1:
failed to retrieve timestamp buffer (default to 0)
