• DeepStream Version 5.0
• Hardware Platform (Jetson / GPU) Jetson Nano
• JetPack Version (valid for Jetson only) 4.3
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) bug
Our C++ version YOLOv5s network model implemented with NVIDIA TensorRT API has almost the same object detection precision as the official python version YOLOv5s if we run our C++ version YOLOv5s network model independently on NVIDIA jetson Nano, but the detection precision is degraded if we integrate our C++ version YOLOv5s network model into NVIDIA Deepstream Infer plugin following the way that NVIDIA integrates the Yolov3 model in Deepstream infer plugin.
I tuned some parameters in detector_config.txt, such as net-scale-factor, but no improvement was seen.
After further investigating, I managed to have found the cause is a timing issue in DeepStream Infer Plugin.
If I add some code in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/nvdsinfer_context_impl.cpp and disable some code in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvinfer/gstnvinfer.cpp, then the detection precision of the yolov5s model running in DeepStream Infer plugin is as good as that we get on PC .
