I am having tiny aliasing issues with this asset:
See, the poster´s edges are flickering:
The Real-time AA Sharpness settings did not made any difference, I think default value 0.5 was the best.
rendering to 3000 pix width and then downscaling in premiere made it a bit better… I would not call this a solution anyhow :P
Hi pekka,
highly detailed textures such as this one can cause aliasing artefacts when undersampled (especially in Real-Time mode). Some AA modes, like DLSS and TAA, are better at dealing with those artefacts in an animation than others.
I can take a look at this scene (or a simplified version of it which still has aliasing) to figure out the best settings if you can share it via direct messaging.
Best,
Sam
Thank you Sam!
I have decided to use path-tracing after all in final renders, so this is not needed. Except if I ran to same problem with PT rendering. I let you know!
