Hi, i recently installed Jetpack 4.6 and trying to benchmark yolov3-tiny using jetson_benchmarks.
I’m getting half the FPS (21) in place of 45, what might be the issue?
clutterbot@jetson:~/infer/jetson_benchmarks$ sudo python3 benchmark.py --model_name tiny-yolov3 --csv_file_path /home/clutterbot/infer/jetson_benchmarks/benchmark_csv/tx2-nano-benchmarks.csv --model_dir /home/clutterbot/infer/jetson_benchmarks/models/ --jetson_devkit nano --gpu_freq 921600000 --power_mode 0 --precision fp16
Please close all other applications and Press Enter to continue...
Setting Jetson nano in max performance mode
gpu frequency is set from 76800000 Hz --> to 921600000 Hz
------------Executing yolov3-tiny-416------------
Model Name: yolov3-tiny-416
FPS:21.32
Wall Time for running model (secs): 489.8842408657074
Thanks for reporting this issue to us.
We are double-checking the performance on JetPack 4.6.
Will get back to you later.
We verify this internally with JetPack 4.6 on Nano and can get 46fps without performance regression.
Could you try it again?
$ sudo python3 benchmark.py --model_name tiny-yolov3 --csv_file_path /home/nvidia/jetson_benchmarks/benchmark_csv/tx2-nano-benchmarks.csv --model_dir /home/nvidia/jetson_benchmarks/models --jetson_devkit nano --gpu_freq 921600000 --power_mode 0 --precision fp16
gpu frequency is set from 153600000 Hz --> to 921600000 Hz
FPS:46.62
Wall Time for running model (secs): 454.495911359787
