This is a how to install nvidia driver 185.xxx on your Ubuntu 9.04… Maybe this is useful to other versions, but it was tested by me on 9.04 and developed focused on it.
You are freakin awesome. I’ve been fighting with the 185 Nvidia driver since it came out. Followed these steps line by line and it worked perfectly. Just have to do the same on my home computer now. Thanks so much for posting this.
I need help following these instructions. X is turned off and the install app run succesfully in ctrl-alt-f1 mode. I had to adjust the directory to home/username from usr/source due to write permission or otherwise inaccessibility of the latter.
Everything works fine except for step 2 generates and error stating that "the package ‘build essential’ was not found or similar. This results (I believe) in the NVIDIA installer reporting that no kernel interface is found and the ftp server for downloading one is unavailable because I am also having problems accessing NetworkManager.
(its not where the documentation says it is even though my networking hardware is detected in Network)
I will update with exact error messages at a later date. Thanks for any assistance,
a seasoned PC user yet Ubuntu set-up noob running 9.04, ubuntu studio…
A bit of a noob here, please excuse my noobness. I am trying to download the proper driver via console and am unsure how to access the right driver from the nvidia site I was planning on using wget, and found this post. The only problem is i am using a different video card and my system is 64bit. How do I tell wget the proper URL to use to acquire the driver I need. I went on the Nvidia site and according to the site I need “NVIDIA-Linux-x86_64-260.19.36.run” just not sure how to tell wget to navigate to this driver on the Nvidia site.
