Tips to improve overall global memory throughtput
Hi there,
I’m really struggling to get any speed-up whatsoever with the code I’ve been porting. In fact it’s actually running twice as slow. I’ve ran a profile on it and it seems two of the device subroutines are running with an overall global memory throughput of less than 3… pretty bad.
I know that to improve this performance I need to ensure that global memory loads are coalesced and/or shift data to shared memory. However, when I tried the latter this actually reduced performance. With regards to coalescing global memory loads I tried to get all theads to read/write to a local variable and then call syncthreads() at the end of the routine to get all threads to simultaneously write the result to global memory…again, this resulted in a slower execution time.
I’m really running out of ideas now so if anyone has any suggestions or optimizations that worked for them I’d love to hear about them. The code follow, bit long sorry.
       attributes(global) subroutine fock2a(iuhf,numthreads,
     & blocksize,natoms,nbasis)
      implicit none
      integer :: norbk,norbl,llk,lll,i,ii,j,jj,ij,ijw,k,kk,l,
     &     ll,kd,ld,kld,kw,lw,klw,iim,jjm,iw,ikw,jw,jlw,
     &     thread,iank,ianl,katm,latm,tx,bx,ijw2,check_katm,check_latm
      double precision :: scale,sum,dx,dy,dz,rab
      integer,value :: numthreads,blocksize,iuhf,natoms,nbasis
      integer ij_check,counter,rowno,col,x,y,start,endd,middle,pair,
     &     kloop,lloop,ijkl,work,remaining,istat
      real temp
c$$$      integer, dimension(*),shared:: s_lowlim
  !    double precision, dimension(45,45):: w2_local
      tx=threadIdx%x
      bx=blockIdx%x
      ij=((bx-1)*blocksize)+tx
         if (ij.le.numthreads) then
            ftot1(ij)=0
         katm=LUT(ij,1)
         latm=LUT(ij,2)
         if (iuhf.eq.2) then
            scale=1.0d0
         else
            scale=0.5d0
         endif
         if(katm.eq.latm)then
c
c     Diatomic vector
c
            llk=lowlim(katm)
            iank=ian(katm)
            norbk=natorb(iank)
            do latm=katm,natoms
               if(katm.ne.latm) then
!     Find integral index for each atom pair
                  pair=0
                  kloop=0
                  ijkl=0
                  do while (ijkl.eq.0)
                     kloop=kloop+1
                     do lloop=kloop,natoms
                        pair=pair+1
                        if(kloop.eq.katm.and.lloop.eq.latm)ijkl=pair
                     end do
                  end do
                  dx=c(1,latm)-c(1,katm)
                  dy=c(2,latm)-c(2,katm)
                  dz=c(3,latm)-c(3,katm)
                  rab=dsqrt((dx**2)+(dy**2)+(dz**2))
c
c     Lower basis functions labels
c
                  lll=lowlim(latm)
c
c     Atomic numbers
c
                  ianl=ian(latm)
c
c     Number of basis functions
c
                  norbl=natorb(ianl)
c
c
c****************************************************************************
c     *        *
c     *        *
c     *    Atom k        *
c     *        *
c     *        *
c
c
                  ijw=0
                  i=0
                  do while (ijw.eq.0)
                     i=i+1
                     ii=llk+i-1
                     do j=1,i
                        jj=llk+j-1
c
c     address in ftot
c
                        ij_check=(ii*(ii-1)/2)+jj
c
c     address ij in w2
c
                        if(ij_check.eq.ij) ijw=(i*(i-1)/2)+j
c
                     end do
                  end do
                  sum=0.0d0
c
                  do k=1,norbl
                     kk=lll+k-1
                     do l=1,norbl
                        ll=lll+l-1
c
c     address kl in dtot
c
                        kd=max(kk,ll)
                        ld=min(kk,ll)
                        kld=(kd*(kd-1)/2)+ld
c
c     address kl in w2
c
                        kw=max(k,l)
                        lw=min(k,l)
                        klw=(kw*(kw-1)/2)+lw
c
c     Total Fock Element
c
                        if(iuhf.eq.2)then
                           sum=sum+(dtot(kld)+dtotb(kld))*
     &                          w2(ijw,klw,ijkl)
                        else
                            sum=sum+dtot(kld)*w2(ijw,klw,ijkl)
                         end if
                     end do
                  end do
                  ftot1(ij)=ftot1(ij)+sum
               end if
               end do
               latm=katm
               lll=llk
               ianl=iank
               norbl=norbk
               do katm=1,latm
                     pair=0
                     ijkl=0
                     kloop=0
                        kloop=kloop+1
                           pair=pair+1
                        end do
                     end do
c
c
                     llk=lowlim(katm)
c
c     Atomic numbers
c
                     iank=ian(katm)
c
c
                     norbk=natorb(iank)
c
c
c     *        *
c     *        *
c     *    Atom l        *
c     *        *
c     *        *
c
c
                     i=0
                     ijw=0
                     do while(ijw.eq.0)
                        i=i+1
                        ii=lll+i-1
                        do j=1,i
                           jj=lll+j-1
c
c     address in ftot
c
c
c     address ij in w2
c
                           if (ij_check.eq.ij) ijw=(i*(i-1)/2)+j
c
                        end do
                     end do
                     sum=0.0
c
                     do k=1,norbk
                        kk=llk+k-1
                        do l=1,norbk
                           ll=llk+l-1
c
c
                           kd=max(kk,ll)
                           ld=min(kk,ll)
c
c     address kl in w2
c
                           kw=max(k,l)
                           lw=min(k,l)
c
c
                           if(iuhf.eq.2)then
     &                             w2(klw,ijw,ijkl)
                           else
                              sum=sum+dtot(kld)*w2(klw,ijw,ijkl)
                           end if
                        end do
                     end do
                  end if
                  end do
               else
c
c
c     *        *
c     *        *
c     *    Atom k - Atom l                                                       *
c     *        *
c     *        *
c
c
c
c     Diatomic vector
c
                  pair=0
                  kloop=0
                  ijkl=0
                     kloop=kloop+1
                        pair=pair+1
                     end do
                  end do
c
c
                  llk=lowlim(katm)
                  lll=lowlim(latm)
c
c     Atomic numbers
c
                  iank=ian(katm)
                  ianl=ian(latm)
c
c
                  norbk=natorb(iank)
                  norbl=natorb(ianl)
                  do i=1,norbk
                     ii=llk+i-1
                     do j=1,norbl
                        jj=lll+j-1
c
c     address ij in ftot
c
                        iim=max(ii,jj)
                        jjm=min(ii,jj)
                        ij_check=(iim*(iim-1)/2)+jjm
c
                        if(ij_check.eq.ij)then
                           sum=0.0d0
c
                           do k=1,norbk
                              kk=llk+k-1
c
c     address ik in w2
c
                              iw=max(i,k)
                              kw=min(i,k)
                              ikw=(iw*(iw-1)/2)+kw
c
                              do l=1,norbl
                                 ll=lll+l-1
c
c
                                 kd=max(kk,ll)
                                 ld=min(kk,ll)
c
c     address jl in w2
c
                                 jw=max(j,l)
                                 lw=min(j,l)
                                 jlw=(jw*(jw-1)/2)+lw
c
c
                                 sum=sum
     &                                -scale*dtot(kld)*w2(ikw,jlw,ijkl)
                              end do
                           end do
c
c
                        end if
                     end do
                  end do
               end if
          end if
c
                                 end
Hi crip_crop,
I’ve been think about this one but am not sure. It seems like the problem would be the random non-coalesced memory accesses, but I guess not. Have you profiled the code?
I’ll forward this on to some of our other application engineers to see if anyone else has any ideas.
  • Mat
  1. You have lots and lots of global memory array accesses that are not going to be coalesced. That may be just an artifact of your application. Look at:
    lowlim(katm) where katm=LUT(ij,1)
    So katm has different values for each thread, they aren’t necessarily adjacent, non-coalesced
    natorb(iank), where iank=ian(katm), same thing
c(1,latm) where latm=LUT(ij,2), same thing
w2(ijw,klw,ijkl) where ijw is set to some value in one of the loops above.
Add to this divergence in loops like the do while(ijw.eq.0)
I’m not at all sure that using local memory is the right thing for you, except for local scalars. Local arrays are implemented in the physical global memory, so you have the same problem of accesses to the global memory, and those accesses are not coalesced.
The code is long and has lots of data-dependent branches and many computed array indices; this results in divergence and noncoalesced loads, which unfortunately is not the application space for which GPUs are optimized.
Hi Mat, yes I profiled the code, that’s how I know the global memory throughput is so low.
The original code is quite different as each thread has it’s own katm and latm but I had to redesign the algorithm because of the summation:
meaning that multiple threads could be writing to the same ij value which gives race condition.
I guess the only way around it would be to just implement this routine on the CPU and pass the data back to the GPU. Hopefully the data transfer overhead won’t be too great.
Cheers,
Crip_crop
[/b]
