Hello everyone,
does anyone have fan problem with your Titan RTX ?
Only single fan runs at it’s full speed right after machine starts, even before it hits BIOS, and never reduce it’s speed.
Tried to manually configure fan speed from x-server, one of fan can be controlled manually but faulty one still runs at maximum speed.
Tried to re-seat, no luck. Changed slots no luck.
Heat is no problem here, it doesn’t get hot; temp is at 41c.
i got another Titan RTX that’s working without any problem, only one card has a left side fan problem.
Anyone fixed it ? any suggestions ?
It’s a new card, just unboxed 12 hours ago. Can’t return because it shipped from other side of the globe.
Even if it is just the fan, AFAIK the top assembly which holds the fans is glued to the heatsink, so disassembly is difficult and and don’t know where to get a replacement fan anyway.
