Hi Tom,
I used GPUZ 2.17.0 to monitor the GPU clock and memory clock of Titan V.
After applying “nvidia-smi --cuda-clocks=OVERRIDE”, the GPU clock speed could reach 1792MHz and the memory clock was 850MHz。But the memory clock was only 425MHz in TCC mode.
However, the results of bandwidthTest of two modes were very close.
# TCC mode
bandwidthTest --dtod
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: TITAN V
Quick Mode
Device to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 548561.6
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
# WDDM
Running on...
Device 0: TITAN V
Quick Mode
33554432 548914.5
Result = PASS
OS: Windows 10
Driver: 419.35
