I’m trying to connect a Titan XP to my laptop running ubuntu 18.04. My goal is to have 2 gpus available in a docker-compose/k8s cluster because I need to run a setup that includes 2 containers that require GPU/CUDA.
I connected the egpu via usb-c, updated my nvidia drivers to 418, and rebooted, but when I run nvidia-smi
I don’t see the second gpu.
Are there any step-by-step instructions for getting a set up like this to work on ubuntu 18.04?
Here’s the output from nvidia-smi (it sees my internal 1070 but not the egpu):
Tue Apr 9 23:27:27 2019
| NVIDIA-SMI 418.43 Driver Version: 418.43 CUDA Version: 10.1 |
| 0 GeForce GTX 107... On | 00000000:01:00.0 Off | N/A |
| N/A 42C P8 6W / N/A | 2MiB / 8119MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
I also ran nvidia-bug-report.sh, but doesn’t seem like I can attach files here? I uploaded the output to google drive here:
Any help with this greatly appreciated.
–Larry
